XJ ( X351 ) 2009 - 2019
Missing badge?
Old 02-18-2018, 07:15 AM
tjankovs's Avatar
Default Missing badge?
I noticed the left rear interior door of my XJL is not like the other. The 'Jaguar' badge is missing, or was never applied. Anyone else see this? Any idea where I can fine one(P/N).
Old 02-18-2018, 09:15 AM
clubairth1's Avatar
Received 2,255 Likes on 1,778 Posts
Doubt you will find it new and I would just look on EBay and find someone parting an XJ out. Send him a E-mail with the picture of what your looking for.
Old 02-18-2018, 11:40 AM
Stuart S's Avatar
Received 6,168 Likes on 3,393 Posts
Is this it? Your Personal Profile says that you have a 2015 XJL. See trim, #8 on diagram. $29.53 from Jaguar Merriam Parts website.
https://jaguarmerriamparts.com/parts...&siteid=215718
All you have to do is Google "OEM Jaguar Parts" and then search those websites by year, make, and model and type of part. No need to ask for help after you learn how to do it yourself.
Hope this helps.
The following 2 users liked this post by Stuart S:
GGG (02-19-2018), Micster (07-19-2021)
Old 02-18-2018, 12:41 PM
tjankovs's Avatar
That looks like it...thanks!
Old 02-18-2018, 03:07 PM
Stuart S's Avatar
Since you're a newbie, you should know to use this button, at the bottom right:
Old 02-19-2018, 02:13 AM
GGG is offline
Received 16,820 Likes on 12,177 Posts
I noticed the left rear interior door of my XJL is not like the other. .....
Welcome to the forum tjankovs,
Old 02-21-2018, 02:48 AM
ABrice's Avatar
I actually just purchased a few of these last week. I just installed them today. Installing them can be a little tricky. It's not as easy as it looks. The diagram in this post is incorrect. The actually part that you're looking for is located on the rear doors, however in the Jaguar diagrams the part you need is listed on the front door. They're $44 each at www.oemdiscountcarparts.com. You need item #16 on this diagram.
Below are the part #'s. One for the left, the other for the right.
C2D37036PMB Bezel
C2D37037PMB Bezel
tjankovs (02-21-2018)
Old 02-21-2018, 07:24 PM
tjankovs's Avatar
Thanks ABrice....that is the one. Never thought to look at the diagram for the front door.
Old 02-21-2018, 08:19 PM
ABrice's Avatar
No worries brother. Be careful putting it on. It's kinda tricky. You'll have to take off your door wood trim, the thin black bezel around the door handle, and the inner plastic piece that you have pictured above. The part will come with the badge already mounted on top of that plastic piece.
Once you have the parts listed above removed, install the badge first. You'll have to do some finaggling to get it in that hole. A small flat head screw driver will help out. Then put the thin black bezel back on. More finaggling. Lastly, put the wood back on.
Old 03-05-2018, 05:35 PM
tjankovs's Avatar
All fixed. I used the following method w/o disassembly.
1. Heat then carefully remove new badge from new assembly
2. Apply a bead of rtv to the back of the badge
3. Put it on and hold for 1 beer
The following 2 users liked this post by tjankovs:
GregW (03-23-2024), JagGate (03-06-2018)
Old 03-10-2018, 03:51 PM
Caribmon71's Avatar
Coming in late to this. Your car may have had it, but you lost it when it fell off. I have a 2016 XJ L that I purchased new less than a year ago. A few months ago I opened the rear door to find the badge dangling by a thread of glue. I pulled it lose and saved it. I have my first service appointment this Monday, where they will reattach it in addition of taking care of multiple other issues.
Old 07-16-2021, 11:49 AM
Pw4247's Avatar
did you find a badge I am missing one on my left 2019 xjr sport
Old 07-16-2021, 12:44 PM
clubairth1's Avatar
Yes he did. Did you read the other posts? Your answer is in there!
XJsss (07-16-2021)
Deggo27
09-17-2017 04:28 PM
GourmetSaint
03-30-2015 08:51 PM
rhriczko
02-04-2011 08:09 AM
01-31-2007 09:28 PM
andersen06
01-07-2007 11:38 PM
Quick Reply: Missing badge?
