XJ ( X351 ) 2009 - 2019
Need help- where does this wire go - near the battery
Old May 4, 2023 | 07:13 PM
jaguarxjl's Avatar
Default Need help- where does this wire go - near the battery
2013 XJL petrol v6
Please see attached pic. Where does that wire go? Where do I plug it in. I was replacing the battery and I might have accidentally unplugged it? I am not sure whether it was ever plugged some where.. I assume it has to be plugged somewhere? Can someone please check their car and help me?
Thanks.
Old May 4, 2023 | 07:21 PM
OzXFR's Avatar
It goes nowhere and is nothing to worry about, it is used once and once only by the dealership as part of pre-delivery set up.
Mods - any chance of making this some sort of cross-forum sticky as this question comes up with monotonous regularity, at least once a month, and has done for the last 15 or so years?
Old May 4, 2023 | 08:49 PM
jaguarxjl's Avatar
That's a HUGE relief, OzXFR!
Thanks a lot! This forum has been so very useful, with knowledgeable people helping.
Btw, for my XJL, I could not unscrew the bolt which holds the battery down, at its base on the + side.
First, it was extremely tight, as I was unscrewing and suddenly, something "gave up" and it started turning freely but would not come out.
The similar bolt at the -ve side came out just fine. I was able to wiggle the battery out anyway.. but I am wondering if this happened to anyone else and what exactly is happening to this bolt as it keep turning but not coming out!
Another question: My 3.5 year old Jaguar OEM battery died completely. Once day, I got a "low battery, start the engine" warning.. When I didn't use the car much, it simply died. Is it possible that the battery failed and that there is no standby current drain?
Thanks.
Old May 4, 2023 | 09:48 PM
ralphwg's Avatar
Depending how often and how many miles you drive at a time; you can expect a battery to die anytime after 3 years of age. Two pieces of advice to prolong battery life. Make sure your new battery is fully charged before you install it and buy yourself a battery maintainer, particularly if you don't drive the Jaguar much. CTeks seem to be the favorite for Forum members. They can be bought on Amazon for less than $100.
Old May 7, 2023 | 02:12 PM
clubairth1's Avatar
Community Influencer
Yes the battery can die just like that. I am amazed that my factory battery will be 10 years old this September! We will see if it makes it!
I have never used a battery tender.
okmores
Jan 30, 2022 05:37 PM
60Gunner
Aug 23, 2021 05:02 AM
FIRE550
Aug 26, 2020 06:45 PM
Jason Souhrada
Jan 13, 2016 04:24 PM
chrismroyle
Jun 21, 2015 06:28 PM
