XJ ( X351 ) 2009 - 2019
Nicodep : my little XJ modded
Old Dec 29, 2016 | 05:19 AM
  #61
nicodep's Avatar
Hi,
See my post on my website, for me it's necessary to remove the front bumper :
http://www.nicodep.net/XJArden.htm
Old Jan 11, 2017 | 11:55 PM
  #62
gagman66's Avatar
Originally Posted by nicodep
Hi,
Thanks. Can you please translate the instructions for wiring the DRL on your website to English? Thanks in advance.
Old Jan 12, 2017 | 07:44 AM
  #63
nicodep's Avatar
Google translate is your friend !!
https://translate.google.com/transla....htm&sandbox=1
Old Jan 12, 2017 | 01:55 PM
  #64
michaelnv's Avatar
Would please share a link for the daytime running lights.
Old Jan 13, 2017 | 09:09 AM
  #65
gagman66's Avatar
Where did you connect power to under the hood? Which component and wire?
Old Jan 16, 2017 | 10:33 PM
  #66
gagman66's Avatar
Smile
Thanks. I did similar to you, but could not afford the Arden option, so I purchased a set of Jaguar XF LED DRL's off eBay and modified them to fit the opening. A lot more work, but $500.00 less.
Also, I wanted the solid LED bar look compared to individual LEDs. Nicodep you are correct, no way I could install these lights without removing the bumper completely.
It took me a lot longer since I didn't remove the tires due to not having proper jack stands. I found out that the car is very low to the ground when wedge underneath.
Old Sep 13, 2023 | 08:02 AM
  #67
griff831's Avatar
gagman, have you had much trouble with these DRL replacements for the front corners? These look great.
Old Sep 13, 2023 | 02:49 PM
  #68
Baltobernie's Avatar
The Hella modules aren't nearly as elegant, but they're $150 and don't require front bumper removal. Ideal daytime output, plus optimal horizontal and vertical light distribution. See post #323
https://www.jaguarforums.com/forum/x...199108/page17/
If you don't want to install additional or replacement lamps, here's another DRL solution:
https://www.jaguarforums.com/forum/x...update-247025/
Old Sep 13, 2023 | 05:22 PM
  #69
EliteZags's Avatar
anyone else really confused why so many on here were commenting on "sideskirts" when there clearly appears to be no sideskirts attached to the car?
do you all have a different definition for sideskirts??
Old Sep 16, 2023 | 11:22 AM
  #70
griff831's Avatar
https://www.jaguarforums.com/forum/xj-x351-53/what-did-you-do-your-x351-today-199108/page17
Thank you! I was thinking about a similar installation from some much cheaper Amazon parts, but I may end up with the Hella option. I am planning to do minimal modification to get the wires through the bumper. I do feel invisible on the road with everyone else having DRLs these days.
Old Sep 16, 2023 | 11:47 AM
  #71
You're welcome. The front corner of the X351 is exactly 30°, so these Hella modules project perfectly. Very rugged and trouble-free after three years. Their intensity and distribution are consistent with OE DRLs on other cars. I used stainless machine screws and fender washers for a secure mounting.
JeffR1
Photography
32
May 4, 2022 11:11 PM
Javier Mena
Europe
Feb 23, 2014 02:44 PM
XF - Xtra Fast
Oct 31, 2012 04:48 AM
Moo
Photography
Jan 25, 2012 04:42 PM
Supralative
Jan 9, 2008 09:20 PM
