XJ ( X351 ) 2009 - 2019
non staggered wheels
Old May 29, 2018 | 09:23 PM
jagmt's Avatar
Default non staggered wheels
anyone on 18" or 19" non staggered setup? will it upset the driving
im currently on kasuga and cost for changing the tyres are high
Old May 30, 2018 | 08:40 AM
Hank Scorpio's Avatar
19" should be fine, there are XJs that come with 19s OEM. 18" might have trouble fitting over the brakes properly, but i think 18s would look ridiculous on this car. 19s are small, and 20s are just about right. we do drive Jaguars after all, you might have to shell out more for tires, but i dont think buying a set of 18s plus a set of tires is going to save you that much money.
i just got a set of Nankang 20s for the front (i know, they are temporary) and they were $75/tire. They are fine, nothing special.
Old May 30, 2018 | 08:52 AM
Stuart S's Avatar
Different brands of tires are available in various countries, and neither your Public Profile nor signature indicates your location.
Provide your location and I might be able to help.
I understand the need for privacy but you don't have to provide your street address. At least your country, and Metropolitan area would be more helpful.
Old May 30, 2018 | 10:37 AM
XJsss's Avatar
IMHO trying a non staggered setup would make for handling and ride inconsistencies.
Old May 30, 2018 | 11:16 AM
There are all-wheel drive XJs now right? They would have to have a square setup, but I am not sure if the suspension itself is adjusted to handle that.
Unless AWD has changed and the tire sizes dont need to match anymore.
Old May 30, 2018 | 02:29 PM
MV Rider's Avatar
I have an AWD and it uses 245/19 in the front and 275/19 in the rear.
Old May 30, 2018 | 03:48 PM
Thermo's Avatar
Veteran: Navy
Hank, with AWD cars, you can run a staggered setup. That in itself is not the issue. What you have to watch is the tire diameters. As long as you keep them the same, you can run whatever size tires you want. You start running different diameter tires, that is when issues come up. For that matter, you could even run (theoretically speaking) a 15" rim on the front with a large sidewall and run 22" rims in the rear with a very low profile tire. May look goofey, but, if you keep the tire diameters the same, the car won't care when it comes to the driveline.
As for what is an acceptable difference in tire diameters, I don't think you will find a hard number. But, the system can absorb a little bit of difference in wheel rotation speed because when you turn, the inside front tire turns fewer times than the outer rear tire. If the system would not be able to handle this difference, every time you turned, you would either break something in the driveline or you would feel the car "hop" as the tires are forced to break traction and slip.
Old Jun 2, 2018 | 10:18 AM
q-man's Avatar
I run with 20"/245 square setup. No issues and it drives just right. Actually my winter tyres were on when I bought car. At spring I noticed that summer aftermarket wheels are square 9". Offset is bit more aggressive on front, but I installed 25mm spacer rear to match looks. Now it looks just right.
kaysid
Jan 3, 2017 09:11 PM
Jandreu
Mar 8, 2015 09:21 PM
jaguny
Nov 25, 2012 04:48 PM
sosoguju
24
Mar 4, 2012 07:56 AM
