XJ ( X351 ) 2009 - 2019
Oil Change
Old Jun 9, 2017 | 01:33 PM
divedy1's Avatar
Default Oil Change
What is the best oil to use for a 2011 Jaguar XJ?
Old Jun 9, 2017 | 02:41 PM
Mikey's Avatar
Any oil that meets the specs in the owner's manual.
Old Jun 9, 2017 | 03:14 PM
Thermo's Avatar
Veteran: Navy
Divedy1, if you go to the dealership, odds are they are going to use Castol because that is what the car was designed to use when it was manufactured. Ensure it is full synthetic 5W-20. There is a number in the owners manual for the oil spec that you should try to meet as not all oils will meet that number.
With this being said, is your car going to break down if you use a different oil, no. Because of the limited number of these cars and the cost of having an oil tested to see if it meets a manufacturer's oil spec, it is going to be difficult to find an oil that is not made by Castol that will say it meets the jaguar oil spec number. I have used a few different oils (all full synthetic) and have not seen any detrimental issues.
dskul1
XJ40 ( XJ81 )
Oct 22, 2017 11:52 AM
middlemarsh
Oct 14, 2016 05:28 PM
IronCobra
Sep 9, 2011 09:55 AM
JohnBurns
Oct 10, 2006 09:55 PM
Sep 25, 2006 10:42 PM
