Oil Filter...
Or else Rock Auto, a huge range at usually the cheapest prices around: https://www.rockauto.com/en/catalog/...il+filter,5340
You want one of the quality brands such as Wix, Mann or Mahle and of those I would go for the Wix 57279.
Also the C2D3670 oil filter is used on a whole range of JLR engines including both the V6 (as per the link above) and the AJ133 V8.
I suggest you check out Bigg Will's oil and filter change philosophy if you wish to keep your engines running for a good distance. I use Chinese made engine oil filters and have found them good for my oil change distance of less than 8k kms.
rsq911
Mar 12, 2016 09:55 PM
