XJ ( X351 ) 2009 - 2019
Oil Filter...
Old Jun 3, 2025 | 12:22 PM
NavyBlue's Avatar
Default Oil Filter...
At my last complimentary annual service for my 2019 XJ, dealer used part # C2D3670 for the oil filter.
Factory OEM pricing is around $30.
But found this on Amazon for $8, with 4.6 stars rating:
Amazon Amazon
Good enough, or is there another good brand name filter...?
Old Jun 3, 2025 | 02:22 PM
NBCat's Avatar
It would be best to stick with the Jaguar filter, or a quality aftermarket filter:
Amazon Amazon
Old Jun 3, 2025 | 08:05 PM
OzXFR's Avatar
Or else Rock Auto, a huge range at usually the cheapest prices around: https://www.rockauto.com/en/catalog/...il+filter,5340
You want one of the quality brands such as Wix, Mann or Mahle and of those I would go for the Wix 57279.
Also the C2D3670 oil filter is used on a whole range of JLR engines including both the V6 (as per the link above) and the AJ133 V8.
Old Jun 4, 2025 | 08:54 AM
JoshMcMadMac's Avatar
I agree with the above, don't skimp on your oil filter. Mahle and Mann do a lot of OEM European filters.
Wix is really well respected.
If you're intent on saving ten dollars, Purolator is a viable option:
Amazon Amazon
Old Jun 4, 2025 | 12:05 PM
clubairth1's Avatar
Community Influencer
I also use WIX.
Old Jun 4, 2025 | 02:21 PM
XKDreams's Avatar
Korop made in China. I wouldn’t trust it.
Old Jun 4, 2025 | 07:22 PM
Six Rotors's Avatar
I suggest you check out Bigg Will's oil and filter change philosophy if you wish to keep your engines running for a good distance. I use Chinese made engine oil filters and have found them good for my oil change distance of less than 8k kms.
kj07xk
Feb 21, 2024 11:34 AM
Whatsnext
Jan 29, 2022 09:15 AM
edadoune
May 8, 2018 09:40 AM
98vpr
Jun 21, 2016 04:29 PM
rsq911
Mar 12, 2016 09:55 PM
