XJ ( X351 ) 2009 - 2019
Power steering pump
Old Feb 1, 2024 | 02:34 AM
danu99's Avatar
Default Power steering pump
Hello. Question for you guys. X351 steering pump. Refurb or second hand or new one?
If refurb.. Where in uk? Who does that and how much it costs if known
Problem being fluctuation of rpm in iddle when turning the steering wheel.
Thx
Old Feb 1, 2024 | 11:26 AM
Vasara's Avatar
Have you tryed to bleed the system?
Best way i have found to bleed power steering have been this method:
- Raise both front wheels up
- Check that resevoir have enough oil
- With engine running turn steering slowly(!) end to end 2-4 times. (until no bubbles appear on oil)
Old Feb 1, 2024 | 12:45 PM
danu99's Avatar
Default Yes
I had the rack refurbed. Profesionaly. Changed the oil bootle with the filter. No difference. Still the revs on idle fluctuate . And more so, like in a thread I read on this forum, sometimes under braking, steering wheel jitters. Diferent speeds. Different moments. And more, on wavy tarmac, it’s behaving funny. Like the steering wheel is going in one direction and immediately in the other direction. For 1-2 cm of steering wheel move. And sometimes ….. just like I need to compensate from wheel being on flat surface . Changed lower arm, upper arm, sway bushings, linkage, pivot, banana arm. Still the same. Because of the revs fluctuating on idle while Turing the steering wheel…… next ideea…. The pump. So….someone? Ideas? Same problem? Ps: balanced wheels , steering angle …. All done also on
Old Feb 1, 2024 | 02:14 PM
wombat's Avatar
It may be the steering rack sensor. I'm presuming that the rpm drops as the wheel is turned?
The sensor feeds a signal to the ECM that increases fuel flow, and maintains a constant idle, as demand on the pump increases.
A good scan tool will give you a code related to that sensor, and it may throw a CEL.
wombat
Old Feb 1, 2024 | 02:26 PM
NBCat's Avatar
Steering wheel flutter under braking is usually caused by brake discs that have uneven surfaces.
Old Feb 1, 2024 | 03:31 PM
danu99's Avatar
not that. I checked.
Old Feb 1, 2024 | 03:50 PM
NBCat's Avatar
How was it checked? Resurfacing the front brake discs may not fully eliminate the distortion.
Old Feb 1, 2024 | 06:01 PM
danu99's Avatar
Default Answer
Totally random behavior. Different speeds…. Different parked pedal pressure….. it’s totally random. When a brake disk it’s warped….. the behavior is consistent. Above 50…. No matter how you press the pedal, the shaking is there. Not in my case. My case it varies from 30 to 100 kph…. And in sudden press it’s fine….. no shaking. I now how a bad disk brake is , I had, this is not the case.
about the question I asked…… about the steering pump….. symptoms I described are without braking. Sudden loss of direction on wavy tarmac and sudden moves ,1..2 cm steering wheel moving
Old Feb 2, 2024 | 08:46 AM
clubairth1's Avatar
Community Influencer
As asked above what codes do you have? Wombat had a good suggestion.
The car is way too complicated to just throw parts at it. Always start with codes and go from there.
Old Feb 2, 2024 | 11:27 AM
danu99's Avatar
Default Scaner
sorry….. I missed that post. Yes…. That’s a ideea. I didn’t use any scaner on the car. What should I look for in terms of scaner? What’s the name? And….. can someone help me with a part number for that pressure sensor? Please! What scanners can read the errors on the car?
thanks for the ideea guys
Old Feb 2, 2024 | 09:04 PM
wombat's Avatar
danu99,
With respect, there are hundreds of OBDII scanners on the market. They range from a few $, and top out in the $$$. Your choice. I use the Icarsoft, my choice.
You didn't answer my question: Does the RPM dip when steering angle is applied with the car at idle?
wombat
Old Feb 2, 2024 | 11:22 PM
danu99's Avatar
Originally Posted by wombat
danu99,
wombat
yes sir, the rpm is dipping when stationary and in idle and I turn the steering wheel
About the scaner, I was curious if all can scan the computer for error s . I had other cars that didn’t work so well with random scanners
Old Feb 3, 2024 | 11:27 AM
clubairth1's Avatar
Wombat is giving you great advice and I want to add if you are serious and want to DIY your repairs. I would get and install the factory manuals?
JTIS-Shop manual
JEPC-Parts catalog. We now have a great bit of software called J-PART that allows us to use JEPC without Flash Player as that has been removed from most computers.
These are free on the forum and yes it will take some work to set them up and get them working as things have changed a LOT since they were released.
To show you the power of J-Part here is a diagram showing the steering rack.
Note the red circle as that's the rack transducer Wombat is talking about. Now again Jaguar does ALL their parts by using the last 6 digits of your VIN (You did not post this so I can't be sure of what part number your car needs?)
I do find part number XR830017 but you MUST check that this is correct for your VIN!
Next you want to also check this part number with a current Jaguar parts system This is simple to do as it may have been superseded? Any of the on line factory parts sellers can do this.
Now it looks like your in luck as that part number is listed for all XJ's from 2004-2019 both V-8 and V-6 cars. But wow right at $500!
I think used would be fine as your problem is very odd and unusual. I don't think I have ever seen a bad rack sensor yet?
Old Feb 3, 2024 | 01:32 PM
danu99's Avatar
JTIS-Shop manual
thanks guys. Great info. I bought a second hand pump to replace and see the difference, will do the same with that solenoid, sensor for the pressure. I know about parts codes, numbers and so on, but thanks for the info.
I will also do a clip with the steering wheel problem to post here for all. Next week will swap pump and maybe check the sensor until spare comes. Thanks again guys.
Old Feb 4, 2024 | 12:15 PM
clubairth1's Avatar
Well sorry for the long reply!
Do post back when you fix it too as I said I had not heard of this before so will be watching your outcome.
Old Feb 4, 2024 | 01:05 PM
danu99's Avatar
sure. And I have a plan for icarsoft v2. Any good? Think tomorrow will do a short film with steering problem.
Old Feb 5, 2024 | 06:48 AM
clubairth1's Avatar
I don't have one so not sure?
There are a lot of choices out there.
Old Feb 5, 2024 | 07:05 AM
danu99's Avatar
Short clip with some kind of jittery steering .hope you can see it. It’s a minor example of the jittery stuff
Old Feb 5, 2024 | 07:54 AM
danu99's Avatar
It seems that I can’t upload the clip
Old Feb 6, 2024 | 03:51 AM
danu99's Avatar
Guys….. 2 questions for you
1. how to upload video? I took the steps with attached video…. Selected…. Upload…. And doesn’t appear in post
2. the jittery steering….. could be from bad strut mounts? Top part of the strut that helps with the rotation when steering? And the foam part that cushions every thing? After replacing the upper arm, I still hear sometimes a noise while starting to turn the steering. Noise is from just under the bonnet, but it’s elusive. Not all moves make noises. So….. could that TOP part of the strut, strut mount, have a large play in it and can’t hold the strut straight under moving the wheel or unde road surface not good?
thx. Thing this week will change the pump . I’ll keep posting info
