XJ ( X351 ) 2009 - 2019
Programming Garage Door Opener
Old Aug 2, 2021 | 12:48 PM
carzaddict's Avatar
Originally Posted by tjankovs
For the last step #7 you press, hold and release the desired button on the visor three times.
Interesting, thats what I was misunderstanding, i thought i had to go back and fourth to press the learn and remote button at the same time. I didnt realize I just had to enable the 'learn' and just repeat the mirror button press 3 times
Originally Posted by Ken Dreger
I did ours today in the heat here in TEXAS, took 3-4 tries but it finally worked. First time I did it the unit undid our Infinity! So I ended up doing both cars again....
my infiniti worked on the first shot.....so does that mean i DONT need the signal repeater?
Old Aug 3, 2021 | 10:14 AM
clubairth1's Avatar
Community Influencer
Correct. Some cars need the bridge and some don't. I ran into the same thing. My wife's Lincoln had no problems with programming to any of our 5 garage doors. Shame it only has 3 positions to program!
But my XJ would not and I eventually added the bridge and then I got it programmed.
Old Oct 14, 2021 | 09:01 AM
Na5h's Avatar
One thing I have learned about this garage opener: the button on my Jag will not work unless the car is powered on. Either have the car running or need the start button pressed to provide power, and it works fine to open/close the garage door. I do not recall the exact method I had used when setting up the car's buttons, but perhaps I did not have the car power on when in my earlier attempts I could not get the car to take the program! So, 'power on' and it will probably take the program and work on your garage door.
Salu498
Apr 3, 2022 09:23 AM
Brian XK8
Jul 6, 2016 06:36 AM
Blacksunshine1972
Nov 2, 2014 05:30 AM
MySType
Feb 18, 2009 08:09 AM
truckdogg4
Jan 8, 2007 10:39 PM
