XJ ( X351 ) 2009 - 2019
RBDS Traffic System
Old Dec 8, 2025 | 03:26 PM
David N. Warner's Avatar
Default RBDS Traffic System
Hello,
The RBDS-TMC traffic service on my 2015 XJL does not seem to be working. Is there some subscription or software update I need to apply to enable it? The traffic in the Atlanta area is atrocious and it would be a great feature to have operational!
Thanks for any advice!
Best, Dave
2015 XJL 3.0
Old Dec 8, 2025 | 07:39 PM
wombat's Avatar
David,
The RDS-TMC system is a fairly complex system, and there are two schools of thoughts on how it works in the XJ.
1. The Nav unit in the XJ is sent signals (via the GPS feed) from other cars fitted with compliant equipment. The Nav then looks at the relative rate of motion of those vehicles against its known database, and recalculates a route. I think this is total bollocks. Not the idea, but how our system works! (I believe this is how more modern cars work).
2. The second idea is that the Radio Data System(RDS) collects data transmitted to/via the Traffic Management Channel(TMC) through local radio FM broadcast stations. Think of it as your FM radio is listening to 2 signals at the same times.
Now it is possible that your local FM stations can't be bothered to transmit traffic data anymore, after all 10+ years is getting 'old-school'. I have also noticed my TMC will 'gray out' in rural areas.
The fix? Check the manual for your MY. It is possible to turn the system ON and OFF, the manual will tell you how. FWIW, on my'12 it's P136-138.
wombat
Old Dec 9, 2025 | 10:59 AM
It appears to be turned on but I get no traffic info on the screen; like road turning green if clear, yellow or red if congested etc. like on my phone. I'll fool with it again when I go out on the road. Perhaps I'm doing something wrong? I'll update when/ if i figure anything out!
Old Dec 9, 2025 | 11:31 AM
12jagmark's Avatar
Now it is possible that your local FM stations can't be bothered to transmit traffic data anymore, after all 10+ years is getting 'old-school'. I have also noticed my TMC will 'gray out' in rural areas.t
It may differ across the model years of the X351, but while the option #1 may be how the 2015 MY operates, at least for our 2012 I'm pretty sure it's this option #2 that you describe.
As such I believe it's 100% dependent on the local radio stations and whether or not they provide the supporting data in their transmission.
I've been in some areas where it's active and other areas where it's not available.
Old Dec 15, 2025 | 05:29 AM
clutchbskt's Avatar
Default subscription
Originally Posted by David N. Warner
Hello,
Best, Dave
2015 XJL 3.0
hi, in order to get live traffic updates through Jaguar incontrol you need to subscribe but you will get live traffic updates through your google or carplay
Old Dec 16, 2025 | 01:34 PM
It appears that In Control is no longer available for a 2015 XJL.
rickspin
May 22, 2025 12:12 PM
Titanium399
Oct 19, 2022 04:44 PM
561JagDad
Jan 8, 2022 05:04 PM
rustytouchet
Feb 26, 2015 09:17 AM
niceguy753
Dec 22, 2014 08:47 PM
