XJ ( X351 ) 2009 - 2019
Rear Hub / Bearings
Old Aug 5, 2023 | 11:56 AM
BenKenobi's Avatar
Default Rear Hub / Bearings
I have a noisy rear bearing so I figured I'd just get a pair of low mileage hubs (both rears) from a vehicle breakers / salvage yard - shouldn't have bothered, money totally wasted.
When Jaguar say that you cannot use hammers or impacts to remove the drive shaft they are not kidding - both units received are wrecked, the bearings are damaged and unserviceable - so if you have the same plan don't bother unless they use the appropriate Jaguar press to remove the shaft (though I'm told this too can damage the bearing as it requires over 12 tons of force to push the shaft out).
I have no choice now but get busy replacing the bearings / buying ready refurbished units though suppliers of same are not easily found.
Greg in France
Feb 20, 2024 12:58 AM
nilanium
Apr 30, 2023 11:09 AM
nakuttaja
May 29, 2020 12:37 PM
bigbore
Apr 14, 2015 04:05 PM
bhmaxjag
Mar 16, 2009 10:32 AM
