XJ ( X351 ) 2009 - 2019
rear not level
Old Dec 21, 2024 | 12:34 AM
dazak's Avatar
Default rear not level
Noticed the rear end was not sitting level one side is 25mm higher that then other, same when car is running.
does anyone know what the correct height should be so i can determine which side is at fault or what the cause could be?
its a 2016 XJ
Old Dec 22, 2024 | 06:05 PM
Thermo's Avatar
Veteran: Navy
dazak, when I played with my car, I noticed that when I measured from the center of the wheel to the top of the wheel well, I was getting an almost exact 400 mm. I would measure all 4 wheels (from center of the wheel to the top of the wheel well) and you will most likely find that 3 are going to be fairly close to 400 and the 4th is going to be different. So, you may see say 395 on the left front, 403 on the right front, 405 on the left rear, and 430 on the right rear. This would indicate that your right rear is the problem.
Vladm69
Apr 16, 2023 07:47 AM
Vlad
General Tech Help
Apr 9, 2023 02:38 PM
Donncha Kearney
Jul 19, 2021 03:39 PM
Dagreeny1
Jan 8, 2021 05:23 PM
Jandreu
Jul 24, 2015 10:01 AM
