XJ ( X351 ) 2009 - 2019
rear parking camera
Old Oct 26, 2017 | 07:21 PM
cw601's Avatar
Default rear parking camera
doesn't work 2013 XJ rear parking not working..ladder of lines refelection off lights at night time ..weird whata going on ?
Old Oct 27, 2017 | 05:43 AM
Partick the Cat's Avatar
You're in the wrong sub-forum OM; this is the one for X350 and X358 XJs which were 2003-9. Yours is an X351 XJ.
Old Oct 27, 2017 | 10:16 AM
Welcome to the forum,
Your post is in the right place now.
Don't forget to post an intro in the new members section.
Old Oct 27, 2017 | 11:11 AM
Hank Scorpio's Avatar
could you elaborate a little bit... so it is working, but there are reflections from lights? or is it washed out? the backup camera is unfortunately very low res (i wonder if you can upgrade it) so it might be getting washed out by the light. Not sure if thats what you mean.
Old Oct 28, 2017 | 03:29 AM
TheBoy's Avatar
I find with the amount of dew, now the cooler nights have arrived, mine is less defined due to condensation on camera. But still able to see things, just a bit blurred.
I don't think it needs to be higher resolution anyway, for those that think an upgrade is worthwhile. That said, I'm more a mirror man.
OP - are you saying you get a black screen, with just the yellow lines on? First off, check camera is still connected, and clean. And that some wise crack hasn't put black tape over the lens (or does that only happen at my works carpark!)
JimC64
Sep 22, 2025 02:52 PM
stmcknig
Oct 17, 2016 07:08 AM
06-XJR
Oct 16, 2016 04:41 AM
X2 Jag
Jan 1, 2007 07:50 PM
JimC64
Nov 28, 2006 10:09 PM
