XJ ( X351 ) 2009 - 2019
removal of "Portfolio" insert on fender badge
Old Aug 20, 2020 | 08:29 AM
Baltobernie's Avatar
Default removal of "Portfolio" insert on fender badge
I dislike this insert on my 2012 XJ and would like to remove it. Does anyone have an exploded image of the Jaguar badge and Portfolio insert?
The Portfolio badge probably has two or three plastic studs traversing the Jaguar badge. Snapping off this insert would leave the stubs, but that part of the badge is black, and the P badge is probably black plastic, too. The alternative is to remove the fender liners and access the complete badge from the rear. How difficult is this? I'm used to having similar fasteners break while attempting to remove.
Old Aug 20, 2020 | 09:30 AM
clubairth1's Avatar
Community Influencer
My only question would be what are going to do about the hole left after removing the badge?
Yes I would remove the fender liner and take a look. I have had both my fender liners off but can't remember if the side fender trim is exposed but I think it must be?
Old Aug 20, 2020 | 12:46 PM
XJ8JR's Avatar
YES, you can access the fender trim with the wheel liners off
Old Aug 21, 2020 | 01:03 PM
clubairth1's Avatar
Hey I knew you would know!
Thanks for the additional info.
Old Aug 21, 2020 | 02:11 PM
Should only be two or three 0.125" ± holes in a honeycomb black background. A dab of RTV would probably work. I'm going to investigate further, and will report findings.
Old Aug 22, 2020 | 10:15 AM
xdave's Avatar
Yes you can remove the insert badges - they are heat staked on from behind so you will need to remove the trim to do so. As mentioned above you just remove the rear of the wheel arch liner and you can get a 10mm ratchet spanner in there to easily remove them (don't drop the 4 nuts!).
You will end up with two holes. Personally, having done this in reverse to take my old autobiography inserts off of silver trims to mount them into replacement black pack trims, I think you would always notice the two holes even with sealant closing them. The holes are bigger than you'd think.
Have you considered selling yours intact on eBay or similar, and just buying the far more common variant without the badges? You would likely make a little money on the difference.
Old Aug 22, 2020 | 10:47 AM
Great photo; thanks. Yes, the holes are larger than I thought. I'll need to re-consider. Can you tell me if all base-level side badges on the X351 series are identical?
Old Aug 24, 2020 | 02:29 AM
christ's Avatar
Originally Posted by xdave
... having done this in reverse to take my old autobiography inserts off of silver trims to mount them into replacement black pack trims ...
You murdered out an Autobiography? You rascal, you.
GilesGuthrie
Apr 4, 2020 02:23 PM
powerhouse
Jun 2, 2019 07:49 PM
OzXFR
May 15, 2018 06:27 PM
aaf8
May 17, 2016 08:37 PM
Lcgi
Apr 2, 2013 06:49 PM
