XJ ( X351 ) 2009 - 2019
Suspension noise
Old Aug 22, 2020 | 07:40 AM
Stics2clips's Avatar
Default Suspension noise
Hello Recently had XJL services at dealership. They replaced uppper lower control arms and bushings. Front end alignment was also performed. However service was performed under extended service contract and the warranty company supplied aftermarket parts. Three weeks later I’m now experiencing front end clunk noise over bumps and road imperfections.
Should I return to dealership and insist they recheck the front at no charge or take it to a independent to inspect the issues. If I go back to dealer and they say something new is wrong. How will that be so if they just completed the repair?
What are the chances other components could have failed after the the control arm and bushes replacement?
Old Aug 22, 2020 | 09:11 AM
XJsss's Avatar
In most cases that front end clunk can be the front sway bar bushings, A good service advisor of tech could check that out.
Old Aug 23, 2020 | 11:20 AM
clubairth1's Avatar
Community Influencer
Did you have the clunk before the work was done?
If not follow what XJsss said above. Maybe add the sway bar end links as a possible cause too.
Old Aug 24, 2020 | 09:35 AM
No I didn’t have the clunking issue until after the repair work was done. I notice a squeaking noise also and took a look at the strut. The center mount looks off center. All this after repair work was done at dealership.
Old Aug 24, 2020 | 10:18 AM
XJsss's Avatar
I would go back and have the upper shock mounts and isolators replaced under your warranty. It's really to bad that the dealership did not contact the warranty company to replace these items when they had the suspension apart.
fastlanz
May 25, 2016 10:40 PM
prosthotoothist
29
Apr 8, 2015 10:49 AM
rjcl004
Mar 25, 2015 03:00 PM
daboss085
Jun 14, 2013 05:45 PM
elmostro
27
Aug 6, 2012 12:54 PM
