XJ ( X351 ) 2009 - 2019
Replacement headlamp: Non-AFS or AFS?
Old Sep 22, 2016 | 02:24 PM
H20boy's Avatar
Default Replacement headlamp: Non-AFS or AFS?
I am going to replace one of my non-adaptive headlights due to an LED in the signature bar failing (how annoying!). Anyway, since I don't have AFS, do I necessarily need to get a non-AFS headlight from ebay, or will an AFS headlamp work without all of the full functionality?
Old Sep 22, 2016 | 05:35 PM
xdave's Avatar
I cant be 100% sure because I've never tried it, but from looking at the schematics it should be possible. IIRC the motor for the AFS (left to right movement) was wired independently on the 2016 lamp units I took apart so it likely just wouldnt do anything, and even if it is connected back to the control module it wont be enabled in the CCF so the instrument cluster won't display the AFS fault lamp even if it detects a fault.
Get two AFS lamps and enable it in the CCF and that may be all you need to add AFS, but again... only an educated guess. The XF owners are more adventurous with these things.
Old Sep 28, 2016 | 04:58 AM
H20boy's Avatar
Thanks, I think I'll give it a try. There are so many more AFS headlights on the used market. I'll follow up after making the swap.
1320racer
Oct 12, 2016 10:16 PM
Darrenmb
Oct 8, 2016 09:31 AM
Mugatu
Sep 25, 2016 12:51 AM
baudrate
Sep 22, 2016 09:07 PM
XK81997
Sep 18, 2016 11:30 AM
