Rims for 2011 XJ L Supersport
Hello,
I currently have the factory installed 20" rims for the supersport model and it's been next to impossible to find winters tires for them (245/40/R20 Front and 275/35/R20 Rear). The ones I did find were about 850 CAD per tire...
So I decided to look into buying 18" rims for use with winter tires that cost 300-400 bucks per tire; however, it's been just as difficult in finding said rims for this vehicle. From what I gather, the specs for the rims are 5x108mm bolt pattern with 14x1.5mm thread. The thread size is what's causing problems, as even the SC model appears to have different diameter threads (12mm vs 14mm).
Anyone on here know of aftermarket 18" rims that fit the supersport model and don't cost over 1000 bucks per wheel?
Also, another option I have is going up on the tire aspect ratio, so from 275/35 to 275/40; not sure if this would cause any issue?
Thanks for the heads up! Are you on 19" or 20"? Do you know the rim specs of your car, specifically the thread diameter and pitch?
What is the reason for going with snow tires? For almost all people they are a waste of money. But, if you insist on wasting your money (or on the off chance that you actually do need them), there is a reason why they don't come in wider widths; They are less effective. There are 225 tires available for 18" wheels.
From what I've read so far, the best size winter tires would be 245/45/R19 for this car.
What do you recommend instead? I know over 90% of the time roads are clear of snow, and that's why I use all-seasons on my awd, but, with such a powerful rwd car, winter tires do offer improved traction on all terrain. Especially when it's cold and the rubber hardens.
I say this with experience as I purchased a set of snows. I used them one time, one season. I have had them for over 6 years. What a waste!
Leo here is a link to my thread from last year. I went with 20" because I think they look a lot better than 19" and I was willing to pay more to not be disappointed with the look of my car for 4-5 months out of the year. I live in Northeast Ohio so winter set is a neccesity. Have summers on the factory wheels and I don't want my wife or nanny driving my 5-7 year old boys around in my 500+ hp rear wheel drive car on summers in the snow.
https://www.jaguarforums.com/forum/xj-x351-53/20-tsw-chicane-winter-tires-174502/#post1595272
https://www.jaguarforums.com/forum/x...2/#post1595272
Winter tyres aren't just for the snow. They make a massive difference when it's really cold. In Toronto I'd have thought that was essential. In MD I expect all seasons are good enough as it's so much warmer
They do, especially when so much torque is delivered to the rear. I usually go with all seasons because all of my other cars have been AWD, but with an XJ SS winter tires are a must. It's just difficult finding reasonably priced winters for the rear wheels, but I've decided to buy rims recommended above and fit either 245/40 or 255/40 on both axles. Probably 245 as they should be better on snow.
carzaddict
Feb 14, 2017 09:06 AM
kid delicious
Sep 3, 2010 12:19 PM
