XJ ( X351 ) 2009 - 2019
Solar Trickle Charging
Old May 29, 2023 | 05:13 AM
Comradboris's Avatar
Default Solar Trickle Charging
Can you set up a solar trickle charger in the XJ and if so can anyone recommend a charger/panel. Does this need overcharge protection?
Any other information on setting it up etc would be appreciated.
Old May 29, 2023 | 09:49 AM
clubairth1's Avatar
Community Influencer
The normal suggestion is to get a CTEK changer.
This is used by JLR in their showrooms.
A number of threads have been posted on the install. You won't regret getting the CTEK unit.
They make a Jaguar branded unit if that is important to you otherwise they are the same charger.
Old May 29, 2023 | 10:05 AM
Vasara's Avatar
Some vehicles have solar powered cooler build in the sunroof, keeping the interior cool on sunshine. (VW Phaeton, if i remember right)
For sure it would be possible to build such a system for vehicle battery. Yes: You need panel & charger. Most of solar chargers are made for storing energy to vehicle type acid-lead batterys, so you have ready solutions available, and they (should) have overcharge protection, what for sure are needed.
I would check the caravan stores....
Old May 29, 2023 | 10:18 AM
OK if you have access to mains power. I wont.
Defender99uk
Nov 6, 2021 11:41 PM
Peter HL
XE ( X760 )
Mar 31, 2019 08:55 PM
richzak
Jan 19, 2018 07:03 AM
apachegogo
Jan 24, 2015 04:09 PM
chazaroo
Feb 10, 2014 07:39 AM
