Fastest XJ Battery Charger? (not jump starter)
Old Jan 23, 2015 | 08:19 AM
apachegogo's Avatar
Default Fastest XJ Battery Charger? (not jump starter)
I've been pointed in the direction of CTEK for trickle charging, but anyone know of a fast charger that can give enough charge to start the ignition from flat, within say an hour?
Ideally not a jump starter or trickle charger.
Old Jan 23, 2015 | 10:35 AM
Mikey's Avatar
You'll need a charger with something like 15-20 amps or so. If your battery is regularly going flat, count on buying replacements of those at frequent intervals.
Old Jan 23, 2015 | 10:48 AM
Sean W's Avatar
Hi Apachegogo.
As a standard charger and float charger, I use two different models, both made by Schumacher. CTEK is overpriced for my needs.
For charging manually, I have model SE 1052. It will rapid charge @ 10 amps (about an hour depending on the state of your battery). It also has 50 amp engine start and 2 amp trickle features but I've yet to use the engine start on my Jag and wouldn't use the trickle charger.
For winter storage I use a float charger, not a trickle charger. Specifically the Schumacher SEM-1562A 1.5 Amp Automotive Battery Maintainer and Charge.
Old Jan 23, 2015 | 04:40 PM
apachegogo's Avatar
Thanks Sean for pointing me in the right direction, Schumacher Speed Chargers look good and popular.
Old Jan 24, 2015 | 04:09 PM
34by151's Avatar
Try this
Powertech 12V 40A 4-Stage Wall Mount 240V Battery Charger - Jaycar Electronics
40A, Bulk, Float and PSU modes
34by151
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
Shaggy9212
XJ40 ( XJ81 )
Sep 14, 2015 08:08 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
