XJ ( X351 ) 2009 - 2019
Sporadic suspension fault message and having difference in suspension height, help!
Old Aug 17, 2018 | 02:08 AM
Maya404's Avatar
Default Sporadic suspension fault message and having difference in suspension height, help!
Recently my XJ is showing the yellow suspension fault message from time to time. Most of the time, the message disappeared after I restarted the car. There is no obvious trigger, driving 70 miles on a bumpy highway has a high chance but still not with certainty. For several times, the "Adaptive Dynamics Fault" also showed, and disappeared after restart. The driving became a bit shaky but that can be subjective.
Tonight, after resetting the message again, I noticed the front passenger side suspension is about 3/4 inch higher than the other wheel, and slow driving did not resolve the difference. This scares me.
Any insight into the problem? And any suggestion is welcomed.
Thanks.
Old Aug 17, 2018 | 07:51 AM
JagGate's Avatar
Carmax?
Old Aug 17, 2018 | 02:09 PM
XJsss's Avatar
I'd check the left rear air suspension. But I.m no expert in this area.
Old Jul 28, 2019 | 06:17 AM
crtfour's Avatar
Well I pulled the rear shock and the wires going to the shock looks like they twisted to the point where they snapped right at the connector. Strange how they would twist in there but regardless that was the problem. Luckily the replacement harness is still available part number LJD3075AB. Once the part arrives hopefully all will be good.
I appreciate the information here!
Rob
Old Aug 8, 2019 | 05:22 AM
Thermo's Avatar
Veteran: Navy
crtfour, out of curiosity, where is the connector located? I am having this issue and it is sporadic like others have experienced. I am looking to check out the wiring and see if I am having the same issue. I would like to take care of this while it is just a nuisance and not a hard fault.
Old Aug 8, 2019 | 07:18 AM
XJsss's Avatar
The connection is at the top of the shock in the trunk under the carpeting.
pdog2000
Mar 5, 2017 07:40 AM
jaglover123
Mar 16, 2015 07:29 AM
Sonic
20
Aug 30, 2014 08:46 AM
oldtrojanrunner
Mar 25, 2014 08:35 PM
