XJ ( X351 ) 2009 - 2019
SSD instead of USB
Old Oct 12, 2021 | 02:51 PM
scotsgeeza's Avatar
Default SSD instead of USB
hi ive formatted 128gb portable ssd to fat32 plugged into usb and its not being seen as connected just says plugin device any help appreciated tia george 2011 x351d
Old Oct 12, 2021 | 07:42 PM
Thermo's Avatar
Veteran: Navy
George, because you are using a SSD drive, vice a stick, the drive is going to need more power than the USB port can make (has the potential to output). I also know that there is a bit of software that is on USB sticks that makes them able to be used. Not having that software on the SSD may be preventing the car from being able to access the SSD.
Old Oct 12, 2021 | 08:30 PM
scotsgeeza's Avatar
Hi thermo thanks for reply do u have any idea of the software needed on ssd that is on usb regards g
Old Oct 13, 2021 | 06:59 AM
Thermo's Avatar
Veteran: Navy
George, normally there is a setting during formatting that says to treat this drive as a USB. That would then install the necessary software to make it work. If you did that, then I am not sure what to tell you.
Old Oct 13, 2021 | 07:09 AM
scotsgeeza's Avatar
oh well back to the drawing board thanks anyway g
Old Oct 13, 2021 | 09:44 AM
Vasara's Avatar
Thermo propbly meant "Removable device" setting, what all USB drives are naturally but not nessesary set on portable SSD:s as default. Should not matter on x351, either the powerfeed, since all normal portable SSD:s use less than 480mA. what USB port can supply.
It is more like that IAMT 2.1 on year 2011 model can´t regonise 120Gb capasity. There was same similar issue earlier on this forum. I think the max was 64Gb, but not sure...?
Old Oct 13, 2021 | 09:47 AM
scotsgeeza's Avatar
Ain’t looking good mate but appreciate your help g
Spyglasscircle
Dec 20, 2024 07:32 PM
jupp55
Jul 9, 2018 04:46 PM
jazzwineman
Oct 24, 2017 05:49 PM
slojotaa
Nov 6, 2016 08:50 AM
2013XK
Dec 14, 2015 02:42 PM
