XJ ( X351 ) 2009 - 2019
sticky controls
Old Jan 30, 2016 | 12:00 PM
tinmantam's Avatar
Default sticky controls
the controls and the area around my touch screen on my 2011 XJ L seem to be sticky, I've tried to clean them to no avail
Old Jan 30, 2016 | 12:42 PM
Stuart S's Avatar
You didn't post your model and year, so I checked your public profile and found that you have a 2002 Super V8. You're in the X351 (current model XJ) forum. You'll have better luck in the forum for your car.
Sticky can result from various sources, some may be water-soluble and others may need a petrochemical solvent. If water doesn't clean it, be careful to not damage that surface with other cleansers. Check user reviews on Amazon for "automobile interior cleaners".
Old Jan 30, 2016 | 12:54 PM
tinmantam's Avatar
Sorry about that, my current Jag is a 2011 XJ L 5.0
Old Jan 30, 2016 | 02:55 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
It seems I read somewhere their is a factory bulletin on this condition for the XJL, and they will replace the offending pieces, at least on cars still in warranty, but don't quote me.
Old Feb 7, 2016 | 02:28 PM
tinmantam's Avatar
thanks for the reply
Old Feb 13, 2016 | 07:24 PM
xdave's Avatar
The kind of non-slip coating used on the plastic trim does wear and break down after a while, leaving a sticky residue that cannot be repaired. I had it on the nav button on my 2010 XJ, and the same on the start button and gear paddles on my F Type. I know neither were cleaned with anything other than occasionally wiped with a clean dry cloth so I think it must be a reaction to oils from my skin. My last phone had a similar sort of non-slip coating on the back case and it too started to degrade around where my fingers held it.
Assisi15
Mar 14, 2016 07:17 PM
XJ6Paul
Jan 31, 2016 10:31 PM
tinmantam
Jan 30, 2016 11:55 AM
Singto
Jan 30, 2016 10:26 AM
Paul M P
Jan 25, 2016 04:33 PM
