XJ ( X351 ) 2009 - 2019
Upgrading the 2010/2011 slow touch screen display
Old Jan 6, 2019 | 04:54 PM
  #121
Shaun Flowers's Avatar
Default Replacement not working
Thanks for that.
how do you know its from a range rover?
i will be looking for another one to buy. What should i be looking for? Apart from the date.
many thanks.
Old Jan 6, 2019 | 06:42 PM
  #122
Cambo's Avatar
Because of the part number, the GK62 prefix is Range Rover Sport L494
XJ is xW93 prefix, look here https://www.jaguarforums.com/forum/x...3/#post1992064
Dual View you want either DW93-10E889-BF or DW93-10E889-BE
Old Jan 7, 2019 | 12:50 AM
  #123
Yes i need a dual view screen. Thanks for your advise.
thats really helped me. Thanks
Old Jan 7, 2019 | 02:58 AM
  #124
toxo's Avatar
I appreciate this is in the X351 forum and is centered specifically around XJs, but I guess there could be some similarity with the XF as many systems are similar. I have a MY2011 XFR which is a recent purchase and the touch screen is infuriatingly slow, and as has been mentioned edging towards dangerous. A bit of scouring eBay and google seems to show that there were 2 touch screen units for the X250, one made by Alpine and one that has Bosch logos on the back - the Bosch one looks similar to the unit you're working with here. I would guess that the one unit is for the lower spec stereo option (no subwoofers etc) and the other unit is for the better system. However it appears that while your units have engineering numbers starting A-F followed by W93 the XF units are labelled A-F followed by X93.
I intend to pop the unit out of my dash later on today to see a) which type of unit the car has and b) whether it's an AX, BX, CX etc. There is a breakers near me which has a 2012 Bosch type (CX93) for £70 which might be worth a punt.
Old Jan 7, 2019 | 03:01 AM
  #125
toxo's Avatar
I intend to pop the unit out of my dash later on today to see a) which type of unit the car has and b) whether it's an AX, BX, CX etc. There is a breakers near me which has a 2014 Bosch type (CX93) for £70 which might be worth a punt.
Just realised I made a mistake in there - the XF units part numbers are X23 not X93! So BX23 is what I suspect I have in mine.
Old Jan 7, 2019 | 03:19 AM
  #126
Cambo's Avatar
No, the system in the XF up to 2011MY is totally different to the 2012MY onward, totally different, nothing compatible.
Old Jan 7, 2019 | 03:20 AM
  #127
toxo's Avatar
That's rather infuriating. Mine is a very early 2011 (in fact I just checked and the date of registration is 23/Dec/2010) if that makes a difference. If not I guess I will just have to live with it!! The noise more than makes up for it
Old Jan 9, 2019 | 08:13 AM
  #128
xdave's Avatar
A non-dual view CW93-10E889-AB has just been listed on eBay for £130 ($170 US). Ships worldwide from the UK.
I'm not affiliated, but if you are waiting for a fully compatible screen to come up then that is one.
(edit - compatible with XJ X351, it is not for an XF)
Old Jan 9, 2019 | 08:30 AM
  #129
christ's Avatar
Aaargh. So close!
If I fit that one to mine (dual view), am I right in that I will get all of the functionality in the back, the only difference is that the front seat passenger can't watch TV/DVD/VCR?
-- toying with the idea of going with that one until a dual view comes in ...
Old Jan 9, 2019 | 11:47 AM
  #130
xdave's Avatar
I believe we have had one member fit a single view screen into a dual view car.
You should retain all features except the front passenger dual view as you have said. The dual view button would just do nothing.
On the other hand you do gain twice the resolution on the screen as half is not used for each seat.
Old Jan 10, 2019 | 03:33 AM
  #131
christ's Avatar
So I rush off to click buy, but someone beat me to it. Next time I'm not waiting!
Thanks for the heads up, xDave!
Old Mar 7, 2019 | 05:00 AM
  #132
christ's Avatar
For those still following this thread, another one (apparently dual view) has turned up on UK eBay:
https://www.ebay.co.uk/itm/Jaguar-XJ...EAAOSwy6hcgOVK
Old Mar 15, 2019 | 11:11 AM
  #133
markstan's Avatar
hi
is it possible to upgrade the screen and add dab as my portfolio does not have it
Old Mar 15, 2019 | 12:02 PM
  #134
xdave's Avatar
Hello,
Upgrading the touch screen is covered in this thread.
You can see how to retrofit DAB on this other thread: https://www.jaguarforums.com/forum/x...ystems-162263/
Old Mar 15, 2019 | 02:03 PM
  #135
clubairth1's Avatar
Community Influencer
When asking questions we REALLY need what car you are asking about!!
It does make a difference.
Old Mar 16, 2019 | 10:02 AM
  #136
xdave's Avatar
Another one on eBay from Lithuania. Dual view. It is at the top range of the prices these normally go for, but I'll share anyway in case you want one and are happy to pay the price.
UK: https://www.ebay.co.uk/itm/143173515815
US: https://www.ebay.com/itm/143173515815
Old Mar 25, 2019 | 01:22 PM
  #137
madman1133's Avatar
So the car I purchased had this upgrade done. However, it seems like some of the functionality was lost. I can't get to the seat massage functions and the parking sensors in the front dont work. Not sure what happened.
Old Mar 26, 2019 | 05:30 AM
  #138
christ's Avatar
At a guess your AW93 was replaced by a DW93 not a CW93, as what you describe appears to be the symptoms that result from such an 'upgrade'.
Old Apr 3, 2019 | 07:04 AM
  #139
christ's Avatar
For those of you to the left of the pond without dual view:
https://www.ebay.co.uk/itm/2010-2012...MAAOSw8ihck82U
Old May 19, 2019 | 09:02 AM
  #140
Default One on ebay.
https://rover.ebay.com/rover/0/0/0?m...2F372672617042
Item no 372672617042
