XJ ( X351 ) 2009 - 2019
Video in Motion...an Easy DIY upgrade
Old Feb 6, 2018 | 06:33 AM
JagGate's Avatar
Can our console screens play movies? I put in a DVD once and it wouldn't read it.
Old Feb 6, 2018 | 10:40 AM
ABrice's Avatar
Yes it does. You have to ensure that you select the correct mode.
Select the My Video option, then hit the "+" button. Next select DVD.
If you've already done that, then you have to ensure that the disc that you're attempting to play is the correct region setting. If you're in the US, I believe we're Region 1. Other regions won't play. I hope this helps.
Old Feb 6, 2018 | 01:01 PM
JagGate's Avatar
I actually don't think I have those buttons but I will check tonight.
Old Feb 6, 2018 | 03:55 PM
ABrice's Avatar
You're not going to have the TV buttons unless you have a TV turner. You should most certainly have the DVD and USB button for sure.
Old Feb 6, 2018 | 05:50 PM
XJsss's Avatar
In addition the DVD will not play on the front screen is the car is moving.
Old Jan 13, 2020 | 05:20 AM
scotsgeeza's Avatar
Default Compatibility
Hi would this work on 2011 xj regards g
Old Jan 13, 2020 | 06:47 AM
christ's Avatar
The unit in the pictures at the start of this thread is an "AW93" which is for model year 2010. It is my understanding that 2010-2013 units are interoperable.
Old Jan 13, 2020 | 06:55 AM
  #28
scotsgeeza's Avatar
Default Info
Do u mean I shud look for aw93 regards g
Old Jan 13, 2020 | 08:05 AM
ABrice's Avatar
If you have a 2011 model year XJ/X351, then the device will work. I highly recommend going this route as opposed to modifying the vehicle’s CCF file to disable the video block setting.
Old Jan 13, 2020 | 08:10 AM
  #30
christ's Avatar
No - I meant that it should work if you have an AW93, a BW93 or a CW93.
Old Jan 13, 2020 | 09:04 AM
  #31
scotsgeeza's Avatar
Default Confirming
Just to confirm the module with 500 written on it regards g
Old Jan 13, 2020 | 12:47 PM
  #32
scotsgeeza's Avatar
Default Vim
Cheers found firm from Portugal on eBay I take it that’s same people u got urs from g
Old Jan 13, 2020 | 05:27 PM
  #33
ABrice's Avatar
You’re correct. I purchased mine from the company in Portugal as well.
Old Jan 13, 2020 | 11:04 PM
  #34
scotsgeeza's Avatar
Default Help
Thanks everyone for ur help gonna go down the module route when I’m back in the black after Xmas much appreciated g
Old Jan 14, 2020 | 05:16 AM
  #35
scotsgeeza's Avatar
Default Arrgh
Just been onto people in Portugal they say it won’t work on 2011 xj so I’m at a loss of what to do
Old Jan 14, 2020 | 04:55 PM
  #36
Badd Johnson's Avatar
Default Video in motion
Do you know if this will work on a 2011 xf?
Old Jan 14, 2020 | 05:35 PM
  #37
scotsgeeza's Avatar
Default Info
Hi mate not sure just send them a message n they’ll get back to you regards g
Old Jan 14, 2020 | 10:00 PM
  #38
ABrice's Avatar
That’s surprising. The description in the listing says that it’s compatible with the 2011 XJ. I’m willing to bet that it will work. There’s not much of an internal change in the nav units between the 2011 and 2013...if any change at all. I have a 2013 XJ, and the device works perfectly fine. I bet that it’ll still work. Just my two cents brother.
Old Jan 15, 2020 | 12:53 AM
  #39
scotsgeeza's Avatar
Yeah bit gutted thought we’d narrowed down solution
Old Jan 15, 2020 | 03:20 AM
  #40
christ's Avatar
H20Boy's original thread shows pictures of the device he had being installed on a 2010/11. (AW93). Therefore if the device is the same as that used by H20Boy, it will work on a MY2011. As far as anyone can tell, the interfaces of the BW93 (2011/12) and CW93 (2012/3) are identical to the AW93, so if the device works on a CW93 it will almost certainly work on an AW93 (... or a BW93, if you have one of those - as you may). The issue may be that MY 2013 part way through Jaguar changed to DW93 (as I understand it) and the DW93 is not 100% compatible with the AW93. ABrice: is yours a CW93 or a DW93? (did you look?)
