XJ ( X351 ) 2009 - 2019
What are you using for Power Steering Fluid on an X351?
Old Dec 20, 2023 | 02:30 PM
mikebaker3's Avatar
Default What are you using for Power Steering Fluid on an X351?
I need to top up my power steering fluid reservoir. Owner manual for my 2014 XJ Supercharged specifies Mobil ATF320 PAS Fluid. I have not been able to find it locally. What have you been using?
Old Dec 20, 2023 | 02:54 PM
mikebaker3's Avatar
Never mind. Apparently I asked the same question back in 2019. I just found that thread.
Old Dec 21, 2023 | 09:56 AM
clubairth1's Avatar
Community Influencer
Old thread I know!
I never could find that Mobil ATF320. After much research I used Mobil 1 synthetic multi-vehicle ATF. Swapped fluids twice so far and it has worked fine. I pull as much PS fluid out of the reservoir as possible and refill. Not the best but after several rounds you will get most of the fluid changed out.
Queen and Country
Apr 7, 2021 06:37 PM
Kewpie
Jan 9, 2017 01:02 PM
Xcat112
Feb 10, 2012 02:39 PM
oldmots
Jul 4, 2008 02:43 PM
