XJ ( X351 ) 2009 - 2019
XJ brake pad review and recommendation
Old Aug 5, 2019 | 03:11 AM
bullittandy's Avatar
Default XJ brake pad review and recommendation
I just changed the front pads on my 2012 XJ supersport with Brembo ceramics and thought I'd share an opinion for people looking at pads.
Previous pads appear to be OEM, huge amounts of dust and they were way too sensitive. A couple of times I would throw my passengers against their seatbelts. Also made a very slight grinding noise at low speeds (drive through line with window open).
Brembos are way more progressive. No noise and expecting less dust. Got 'em from Rock Auto.
Old Aug 5, 2019 | 09:17 AM
Nedoerr's Avatar
Thanks for sharing your experience. Do you have a part number for these? We’re they the same size/ shape as OEM? Thanks again.
Old Aug 5, 2019 | 10:22 AM
Brembo P36025N, fit perfectly
Old Aug 5, 2019 | 02:36 PM
XJsss's Avatar
If you go to Brembo's site you will see thay have the matching rears P36026N
Old Aug 9, 2019 | 03:48 PM
XJsss's Avatar
Bullittandy I ordered a full set of these and wonder how they are working out for you now that you have had them on for a time?
Old Aug 9, 2019 | 10:12 PM
Stuart S's Avatar
Subscribed.
Old Aug 10, 2019 | 09:49 AM
I've got a couple hundred miles on them and first impressions remain. I should add that pedal feel remains firm though maybe slightly softer than the stock pads but not objectionable.
Old Aug 14, 2019 | 11:45 AM
Nedoerr's Avatar
Where did you get your whole set from? Rock auto only has fronts in stock. Thanks
Old Aug 15, 2019 | 07:45 AM
Enosgl's Avatar
Try looking at Rock Auto by part number "P36026N", They show one set in stock for $30.00.
Old Aug 15, 2019 | 08:34 AM
XJsss's Avatar
I bought mine off the Brembo official site. they were a bit more but the came quickly. I haven't had them installed yet, but will report back after I put some miles on them.
tinman203
Sep 25, 2018 10:15 PM
hafren
May 12, 2018 12:15 PM
RSpi
Apr 1, 2017 11:34 AM
mbates50
Mar 31, 2013 02:12 PM
Rique
May 4, 2012 09:26 AM
