XJ ( X351 ) 2009 - 2019
XJL 2013 AC not cooling while car is idle
Old Oct 31, 2018 | 06:10 AM
Bader's Avatar
Default XJL 2013 AC not cooling while car is idle
Someone told me that the AC compressor needs to be changed and another person said that it is an electrical fault. Looking forward to your feedback.
Old Oct 31, 2018 | 07:58 AM
Fraser Mitchell's Avatar
What checks have you had done ? Normally, an air con technician will check the refrigerant quantity in the system. This is done by evacuating and then weighing it. I suspect you're down on the amount required. The climate control system on these cars normally gives very little trouble, but some people turn off the air con part of it to "save money" and then end up with a duff compressor costing hundreds of pounds/dollars to replace. Some saving !!
Old Oct 31, 2018 | 08:46 AM
XJsss's Avatar
Take a look at this post as I had the same issue and replacing the valve that I had was the problem. My AC now cools at idle. https://www.jaguarforums.com/forum/x...ciated-206120/
Old Dec 12, 2018 | 12:21 AM
jigginadeal's Avatar
Bader did you find the issue? Sounds to me like the fans are giving out. If you can make it happen at home in your driveway put a fan in front of your grill and see what happens. Good luck.
Old Apr 7, 2019 | 09:42 AM
din888's Avatar
Mine is a 2013 with 63k km on the clock. Had to change the compressor. Such a let down for a relatively new car.
Kyng Kyle Chestnut
Apr 19, 2018 04:04 PM
Alex Martinez
19
Feb 28, 2018 02:14 PM
KingFala
Aug 19, 2014 04:34 AM
Executive
Jun 26, 2013 10:22 AM
monchie313
Oct 22, 2011 08:00 AM
