XJ ( X351 ) 2009 - 2019
XJL Rear trays don't go down all the way
Old Dec 14, 2010 | 06:35 PM
viperz06's Avatar
Default XJL Rear trays don't go down all the way
So has anyone had this fixed and what does it entail? I am almost afraid to take my car back to the "zoo" again.
Old Dec 15, 2010 | 09:00 PM
jaglover922's Avatar
They only travel a certain distance anyway, for example if the rear seat is recline more forward, as oppose to more rearward, the trays look like they don't go down all the way. Normally they are slightly less then 90 degrees. Now if they are 45 degrees or less then I would say yeah there's a problem.
Old Dec 18, 2010 | 05:32 PM
Jagtech's Avatar
the trays don't go flat. they stay in a angle. normal.
Old Dec 19, 2010 | 12:08 PM
viperz06's Avatar
in my 1880 serial number they do not "lock out" at the bottom. on my 10800 serial number they "lock out " at the bottom.
Old Dec 21, 2010 | 06:38 PM
Jagtech's Avatar
what do you mean lock out? the tray latchs don't work???? thats a fix part of the K064 recall
Old Dec 22, 2010 | 06:04 AM
viperz06's Avatar
I mean when you put the trays in the down position the hinges are not fully extended and you can't push it down far enough to make them fully extended. It is obvious that the tray is not in it's intended final position. Not even close to flat, you can see it needs to go further down, but it won't go that far. When they are closed the top latch works.
Old Dec 22, 2010 | 10:44 AM
gears's Avatar
Not sure, but mine don't go down all the way. But seem to be down as far as the hinge allows. I don't think they ever are going to be at 90 degree. Mine stop at about 10 degree "upward" with seat backrest in an average position.
Old Dec 22, 2010 | 12:03 PM
amcdonal86's Avatar
In my X350, you just have to adjust the seat back angle. Compromises have to be made if you want the trays completely flat!
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
Harry Dredge
Sep 3, 2015 03:04 AM
innzane
Sep 2, 2015 10:08 AM
