XJ ( X351 ) 2009 - 2019
XJR 2003 Front & rear passenger doors won’t unlock!
Old May 5, 2022 | 07:44 AM
v8xjr's Avatar
Default XJR 2003 Front & rear passenger doors won’t unlock!
Hi! So I had an issue with driver side door latch stuck, sent to garage they managed to fix but now ended up with both front & rear passenger doors stuck deadlocked. Can’t unlock by hand and or key, in addition to this parking sensors have stopped working too! Makes the bleep but no warnings:.While the car was in for the drivers door, garage managed to drain the car battery and had to be jump started, could this possibly be linked at all? The garage have no idea and can’t seem to fix the problem and am totally lost as what to do?! I’ve had issues with doors over the years with being unable to open various doors but generally the garage have been able to sort relatively simply… on this occasion am stumped! They’re also the local jag specialist…. Anyone had similar issue more so the door issue if so have u managed to get sorted? Many thanks!
Old May 12, 2022 | 10:09 PM
Stuart S's Avatar
The reason for no replies is because you posted your inquiry in the wrong forum. This is the X351 Forum, for the 2009-2019 XJ models. You should have posted in the forum for your 2003 XJ.
https://www.jaguarforums.com/forum/
Wahooesprit
Sep 13, 2016 02:25 PM
Melandra Bethell
Jul 1, 2015 07:20 AM
efgpa
Feb 20, 2011 12:45 PM
bobandgwen
Apr 12, 2010 08:22 AM
GregC
Jan 27, 2010 09:15 PM
