XJ XJ12 ( X305 ) 1995 - 1997
Battery Drain
Old Feb 6, 2019 | 10:41 AM
Flex320's Avatar
Angry Battery Drain
Hello,
I recently bought a 1996 XJ12 and the battery is dead in Lee’s then 20 mins, it’s a brand new battery, I’m thinking it might be the electric cooling fan, but not sure has anyone else seen this problem?
Old Feb 6, 2019 | 11:11 PM
Lady Penelope's Avatar
New batteries have a quality issue these days
Personally I would remove the battery and have them test it on the test bench in the back of the auto parts store
To properly do the test requires 1 hour
Pm me to alert me of your results as I don;t normally monitor the V12 section
The V12 ,Iinline 6 and even the V8 versions of the X300 / X308 series is of about the same electrical layout
Parasitic drain is the term used when the car fails to go to sleep after he key is removed but continues to stay alive , but this is a large drain rate in your case
Quick possibility is the fan control module under the car fwd of the front left wheel is full of water as it hangs not as designed but water creeps in keeping power on the fan motors
The wires coming out of the module should point down
The part # for the X300 and X308 versions of this fan system fan control module are different and the X300 is white and the X308 is black
By removing the module and shacking you can hear the water if present
See page 81 :
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Editing with pic
Old Feb 7, 2019 | 08:13 AM
Flex320's Avatar
Default Battery Drain
Thanks so much I’ll take a look
Donald10
Jul 7, 2025 03:43 PM
carboy
Jun 11, 2023 03:25 PM
monahans10
Jan 13, 2012 03:35 PM
foresme5
Oct 5, 2007 10:18 AM
Apr 25, 2007 04:47 PM
