Drain on Battery 1994 -- XJ12
Old Feb 3, 2008 | 08:34 PM
fall4it's Avatar
Default RE: Drain on Battery 1994 -- XJ12
Check out this product, this could solve your problem, auto-parts stores should carry it.
http://www.batteryguard.net/eliminator.htm
Old Feb 3, 2008 | 09:32 PM
FactoryJaguarTech's Avatar
If you are leaving your doors etc open, pulling the fuse for the lights won't help. You also need to latch the doors so you can leave them open without the car knowing theyare open. I dont trust the test light method. Use a meter in series and should have no more than 0.3 amps after car goes to sleep. Once it is asleep if you have over that, start pullingthe fuses 1 at a time. Start with obvious things such as interior lights, radio, instrument pack etc. Once you pull it, leave it out until u are done so you dont wake up vehicle again.
Old Jan 13, 2012 | 03:35 PM
400gp's Avatar
see posts about cooling fans running even when your not there,fan relays need replacing,at front left under bumper behind plastic panel attached to inner wing,disconnect fan relay fuses 2 of
aholbro1
Dec 29, 2024 06:46 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Scarecrow
Mar 28, 2016 03:17 AM
Charlene n John
Sep 14, 2015 10:08 AM
obwoodie
Sep 3, 2015 07:45 PM
