XJ XJ12 ( X305 ) 1995 - 1997
Engine oil leak
Old Apr 2, 2023 | 03:15 PM
Stu Jags's Avatar
Default Engine oil leak
I seem to have developed an engine oil leak, increases when running at higher revs. Back of engine dripping from plate between engine and gear box but possibly higher up and running down ? Any suggestions on what to check ?
Old Apr 2, 2023 | 04:04 PM
944play's Avatar
Perhaps the oil pressure sender at the top rear of the valley plate? (#19)
Old Apr 3, 2023 | 12:44 AM
Parker 7's Avatar
You probably already have this
2 files below
See page 193 of the 801S doc
This is specifically for the Nippon / Denso ECU V - 12 engine version
Can't find the other V - 12 PDF , maybe tomorrow
File Type: pdf
Old Apr 10, 2023 | 10:32 PM
SleekJag12's Avatar
Most likely its the oil pan gasket. It will drip from between engine and trans. My car is leaking at the pan gasket and will get a replacement at the next oil change.
Pan gasket change is the easiest compared to other possible sources of leaks, like sandwich plate or rear seal.
Old Apr 16, 2023 | 03:37 PM
Stu Jags's Avatar
I think it might have fixed itself, certainly not going to be looking too hard to find another fault. On a positive note, took the car for its first proper drive today. What an absolute beast they are, power, handling and comfort.
Old May 14, 2023 | 08:40 PM
nileseh's Avatar
Good that it's no longer a problem, but if it comes back....
My 6.0 had a severe rear oil leak when I bought it for parts, but the engine ran great and the body and interior was in pretty good shape. I had the engine pulled to see what the problem was. It was the rear main seal. I recall it is a full annular oil seal, and it had moved out of its seat in the block and was spinning with the crankshaft, not doing much sealing. We put a new seal in, made sure it would stay in place and the car has been brilliant since. I fixed the interior bits that were broken, but it didn't take much to make it a wonderful car.
ExcelsiorZ
Sep 14, 2024 08:57 AM
ray13
Mar 28, 2023 07:18 PM
Catfan01
Dec 21, 2019 11:38 PM
Slownot
Aug 10, 2018 11:14 AM
daboss085
Aug 31, 2013 06:35 PM
