XJ XJ12 ( X305 ) 1995 - 1997
Help key will turn on but stuck in ignition
Old Dec 25, 2014 | 07:41 AM
bmorenmiami's Avatar
Default Help key will turn on but stuck in ignition
i have a 1996 vdp just got it running great ...bought from auction it came with two keys...i used the green one for ignition...worked fine in and out...i also received a black one which i used for the doors ...i mistakenly put that one in ignition and voila stuck! what do i do.
Old Dec 25, 2014 | 12:32 PM
gatekeeper's Avatar
Not sure, but try disconnecting the battery. If it comes out good. If not try jiggling the steering wheel while doing the same with the key and trying to pull it out at the same time. Things to try that won't hurt anything. Let us know if it comes out or you need more options.
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
avern1
Sep 8, 2015 06:25 PM
Sprayall
Sep 3, 2015 07:49 PM
