XJ XJ12 ( X305 ) 1995 - 1997
Odd and Highly Technical Question
Old Dec 16, 2023 | 07:54 PM
BenKenobi's Avatar
Default Odd and Highly Technical Question
1996 model overmats - originals - the really deep sheepskin types - did they only come in three's or did the driver get one too - because if the driver got one I am missing one in a car I am about to close a deal on.
Also need a replacement rear view mirror but so many are offered on Ebay that selecting the correct one is a nightmare.
Old Dec 16, 2023 | 08:15 PM
Jagsandmgs's Avatar
Just three! The chauffeur gets nuttin’
when you find a mirror let me know, I could use one.
Old Dec 16, 2023 | 08:18 PM
BenKenobi's Avatar
Good to know I'm not chasing a myth - which I was - as far as the mirror goes it would be good to know the Daimler part number - once the car lands I will pull the mirror and dig in more detail.
Old Dec 17, 2023 | 12:06 AM
944play's Avatar
My car came to me with a Jaguar-branded lambswool driver mat. However, as the rear rugs were (incorrect) LWB spec, there's no reason to believe that any of these were original to the car -- perhaps you had to order the accessory set to get a driver's side.
I'm referring to them in the past tense because I got a new-old-stock "Tailored Carpet Set" of floormats, and while in storage, the lambswool rugs fell prey to moths.
Old Dec 17, 2023 | 03:56 AM
Jagsandmgs's Avatar
Based on that picture, I went back and looked at the accessories parts listing and sure enough there are four carpets. Both XJ12s I’ve had only had three but they were trash cars! Maybe someone just threw them out.
Old Dec 17, 2023 | 04:36 AM
BenKenobi's Avatar
I have also just seen a pic of one that has 4 mats too - one things for sure this is a treasure hunt - I did drop lucky on a mirror though didn't even haggle and bought it, images say it is the correct mirror but was listed for a Jaguar X300.
edit : Did these cars come with a no glovebox option - the car doesn't have one but I've seen pictures of cars that do
Old Dec 17, 2023 | 05:09 AM
944play's Avatar
Early '95 cars didn't get a glove box, but an accessory kit was later made available that provided one, as I understand.
This '96 DD6 apparently doesn't have a 'box. Weird.. (17:49)
Old Dec 17, 2023 | 05:11 AM
BenKenobi's Avatar
That very car is the one that triggered the question .... it is only just a 1996 - first registered 30th Dec 1996
Old Dec 17, 2023 | 06:41 PM
Parker 7's Avatar
On the rear view mirror there was a TSB or something to change to one that does not leak causing the bad optics
There are 2 different types of mechanical disconnects of the small glass adherence piece and the stem / case / frame
You can keep the original glass adherence piece in place , there is a modification to the wiring between the 2 versions
The internals to the upgraded mirror will swap to the shell of the original case / frame to be able to use the original glass adherence peice
I was fortunate to have a salvage yard in town that I was able to source the 4 good condition floor mats as pictured in post # 4 and mirror
Rubbing the mats with soap will wear the skin off your fingers
Docs coming
Genuine Interior Rear View Mirror For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Old Dec 18, 2023 | 03:54 AM
Scott74's Avatar
Registration date and build can be quite different. Mine was built in September 94' but only registered in February 97'. And to top it off, it has a glovebox. The history on my car is very extensive and nothing to clue that it might have been a retrofit.
https://carsonline.bonhams.com/en/li...5-04135bfd1da7
It's on for a no reserve auction over Christmas as unfortunately I only have two car spaces and the XJ is the least practical at the moment for our needs.
Old Dec 18, 2023 | 04:28 AM
BenKenobi's Avatar
Nice car, few issues but mostly niggly stuff, I won't be bidding though as I refuse to add near 1k (maybe more) to the purchase price because it is at Bonhams - 7% of bid pice + VAT or a minimum of £700+VAT buyers fee - no thanks.
Old Dec 18, 2023 | 04:38 AM
Scott74's Avatar
Sure. It's fairly standard for any auction. It's on sale from the first bid so could go very cheap. Will probably sell for less than the high peak car is on for which still needs 600 quid spending to sort out the sagging headlining. All the best anyway and hope you find a nice car. Definitely a buyer's marketplace right now.
Old Dec 18, 2023 | 05:03 AM
BenKenobi's Avatar
The High peak car needs around 2k if my estimates are correct, there is a hidden story that is not clear, the response I have had so far has not impressed me, I will not be chasing them again,
As a bit of back story I have determined that the X351 and I are getting a divorce, not starting a debate on why, worst damn XJ I've ever owned.
If Bonhams weren't greedy and setting minimums (which I guess they do to keep the greater unwashed away) then I'd consider but £700 + VAT is a step too far - I didn't make my money by being stupid with it (says somebody with a V12 XJS)
NYCJAG2006
Dec 25, 2023 08:55 AM
xjfourty
Dec 24, 2017 09:18 AM
KayScotts
Apr 30, 2016 02:42 PM
mike99910
Feb 19, 2014 07:26 AM
ticklemethu
Sep 8, 2008 12:28 PM
