XJ XJ12 ( X305 ) 1995 - 1997
Radiator Fan Temp Sensor Pinout - PDU Success!
Old Oct 10, 2024 | 06:21 PM
Jagsandmgs's Avatar
Default Radiator Fan Temp Sensor Pinout - PDU Success!
Just sharing a small victory. I have a PDU and it’s been pretty useless as a diagnostic tool. But it does have a neat connector pin out lookup! The radiator fan temp sensor has a three wire plug. One wire was broken off so I cut off the pig tail and ordered a new one. Then I lost the old one and no longer knew which wire went where in the connector. With the PDU I was able to look this up!
Old Oct 10, 2024 | 11:54 PM
Parker 7's Avatar
To know the cooling fans circuit works minus the 86 and 100 C temp switch :
put a paper clip between a White wire to the Black wire ground / low mode fans
remove paper clip and the other White / Blue wire to Black ground / high fans mode
Low current section of the fans circuit so no arcing hazard
With the TSB mod done you will always have low fans mode with key on ( protects from both fans coming on to high mode from zero blowing the fuse related to A / C freon load / pressure and you have no engine cooling )
michaelgilbert
Jan 21, 2024 07:49 AM
markbam
Nov 27, 2022 02:58 PM
Jan Christian
Jan 4, 2022 05:23 PM
NobbyXKR
Apr 29, 2015 03:22 PM
fritzvis
Jun 18, 2013 10:20 AM
