XJ XJ12 ( X305 ) 1995 - 1997
Radio code
Old Feb 4, 2025 | 12:42 PM
Apapabenjo992$'s Avatar
Default Radio code
I have a 1996 XJ Sport. New battery and radio code supplied with car does not work. I am told that i should press pty >> a.mem. Only problem is that i do not have a pty button on the radio. Any ideas please. I miss my music.
Old Feb 5, 2025 | 02:09 AM
Parker 7's Avatar
1996 XJ Sport would be a X300 model that has more traffic for more input , even though the X305 is the same chassis and radio it is the V - 12 version
Does the radio have the original Jaguar label on the face ?
This is a Alpine manufactured AJ9500A model # for 1994.5 - 97 , A same looking AJ9500R was used later years in the V - 8
There are a couple of fuses for the radio system and once in me installing battery in backwards it blew one on these radio fuses , battery positive post goes car fwd , mark with tape and big arrow
The USA models in this X300 model year group as original stereo from my understanding should not need a stereo security code to reset the stereo
You are also fortunate to not have chip in ignition key ( engine starting immobilzation ) as well in USA for this group
See about page 21
X300 1996 LWB.pdf
Old Feb 13, 2025 | 02:27 AM
SleekJag12's Avatar
Default A vastly superior sulution
New modern Sony head unit.
I finally replaced the factory head unit about 3 years ago and am very happy with it. Looks nice too. Matching color palettes, bluetooth, aux input, CD player, remote. It even replaces the broken clock! A big win.
No codes needed for USA factory radios, but by now most of the survivors have died. Like the dinosaurs they were.
Old Feb 13, 2025 | 03:49 PM
Parker 7's Avatar
There is some traffic in the X300 area on the details to installing the aftermarket stereo heads
Do you currently have a in the trunk power amplifier and a CD changer in the trunk' ?
The same Jaguar / Alpine AL9500A stereo head will run the standard Jaguar factory wiring where the speaker wires come from the head as in the pic above . Or the factory premium option where the speaker wires come from the trunk located power amplifier ( so may be a matter of having to run new speaker wires )
To make a trunk amplifier work there is an 8 pin DIN cable that runs under the center consol
In some cases this cable is already there to use otherwise not ( extra ) used in the standard setup
To know if you have this tan colored round 8 din cable already installed it will run under the center console ashtray along with a black round antenna cable , no stereo head removal needed to get into that area behind it
Ask Questions
brinny
Oct 16, 2024 11:26 AM
John Baulch
Jun 24, 2019 07:05 AM
John Baulch
XJ XJ12 ( X305 )
Nov 8, 2018 08:55 PM
John Baulch
May 18, 2018 04:47 PM
car5car
Feb 6, 2016 04:03 PM
