Restoration/Repair Project with my Dad
G’day deskinabox,
Wow! Two double sixes and they look to be in pretty good condition.
Here is a link to lots of Jag publications you will find very handy,
https://www.jaguarforums.com/forum/x...48/#post263943
Where abouts are you?
Cheers and good luck,
Jeff.
Jeff.
any idea what is wrong with them? Do they start?
Brake fluid is a great idea. Coolant has anti corrosion properties that don’t last forever so change that too. The fuel pumps tend to seize up with disuse. Don’t buy anything expensive, the cheapest fuel pumps on earth have my car running for ten years now. There are TWO identical fuel pumps in the tank. There are two short fuel lines between the fuel rails that get hard. Power steering pumps leak but are very easy to rebuild.
