XJ XJ12 ( X305 ) 1995 - 1997
Wiper activation issues
Old Aug 21, 2023 | 12:55 PM
Scott74's Avatar
Default Wiper activation issues
Hi all,
Having driven 2000 miles or so now on my new to me XJ12, I have my first issue that needs proper attention. Started raining heavily the other day, went to turn on the wipers and nothing, not a single thing in any postion and pump also not activating to squirt water on the screen. Fortnately was just a few miles from home and the shower passed.
Then set about reading locations for fuses and relays. Checked those out, all fuses intact and swapped relays around with no change.Pulled the car out to give it a wash and suddenly wipers working again. Very odd. Put the car back, wipers not working. I then left the wipers in the on position for a short drive to see whether they might spontaneously come back to life again. When turning the wheel nearly full lock, they started working, then stopped when straightening up. Adjusted the steering column out slightly and they now work all the time. Obviously, I'd rather solve the root cause but I've no idea what the cause of this issue might be. For now I've turned the column off 'auto' and kept it in the golden position.
Would love to hear your thought. My first thought was some wire has become compromised within the steering column but looking at the assembly on ebay, it all looks quite self contained.
Old Aug 27, 2023 | 02:39 PM
Parker 7's Avatar
The control switch has wires that come off the switch , you can just reattach them
Some others had the same thing and column movement may be the clue
TonyLimoZines
Jun 18, 2023 06:49 AM
Ionut Most
Apr 2, 2021 10:28 AM
n1068d
Nov 27, 2017 04:40 PM
Z20
May 14, 2017 12:48 AM
stuart goodwin
Sep 29, 2016 12:02 AM
