XJ XJ12 ( X305 ) 1995 - 1997
X305 starter engages itself while running
Old Jan 20, 2019 | 08:48 PM
Chuckw97055's Avatar
Default X305 starter engages itself while running
...and wipers, hazards, lights, and some motors under hood, all random and without obvious connection.
To be clear, car starts normally, then randomly engages starter, hazards, lights, wipers and a few other things without user input.
Could be moisture, but what module controls all those circuits?
BPM?
Old Jan 20, 2019 | 09:48 PM
Lady Penelope's Avatar
Researching , be right back
Meanwhile for entertainment :
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
See page 54
For the starter to engage the BPM must provide a ground at pin 33 for the starter relay to close
See page 213
As the wiper relay also gets a ground by the BPM pin 27
See page 115
Hazards the same BPM
The common factor is the BPM but has different input wires to command the different subsystems
Before sourcing a replacement BPM notice the case ground that from experience on other things has an effect on module function
Old Jan 20, 2019 | 10:31 PM
Sounds like the BPM then. I'll dig it out and check for moisture.
Thanks,
Old Jan 20, 2019 | 10:40 PM
Have fun digging it out
BPM part # for V 12 ?
An easier try is a hard reset that will get it to zero state and go from there if somehow it went nuts mid drive
Old Jan 20, 2019 | 10:44 PM
Yeah, tried the hard reset. Same problem intermittently. Recent heavy rain, puddle on passenger floorboard, so likely culprit. Thanks for resource and confirmation.
Old Jan 22, 2019 | 08:35 AM
Andrew Harper's Avatar
With regards to the puddle, might be worth taking off the scuttle cover at the base of the windscreen my friend.
When I had my windscreen taken out recently I found corrosion (and a few holes) under the scuttle cover, so may be best to check just in case. '96 car.
I guess the water and muck gets trapped under there.
Old Jan 22, 2019 | 10:00 AM
Yeah, that's on the list. It was parked under a messy tree for a few years by the previous owner so we went through all the drains and unplugged them, but didn't get around to the cabin air system.
Added a space heater to start drying it. Now its dry in the passenger footwell but there is condensation everywhere else. Gotta love living in the PNW without enough garage space.
Old Jan 22, 2019 | 11:01 AM
Tell me about it my friend, I have a drive but no garage so all the work I have to do is outside. Great fun doing a service underneath the car with your legs pointing into the road....
The car has a cover which obviously shields it from the elements a little but I'm certainly looking forward to the warmer (or drier) months! lol.
Fingers crossed you resolve your issue quickly, these are certainly lovely cars to own (when they behave )
Old Mar 2, 2019 | 08:43 PM
I changed out the BPM:
Everything except the starter behaved properly.
I checked the starter solenoid wire and it wasn't energized.
I guess the solenoid was welded closed... I tapped on it and it released.
Everything works normally now.
Old BPM was full of moisture.
Thanks for the help.
thomash85715
Dec 8, 2015 02:16 AM
millertic
Oct 25, 2015 08:42 AM
Johnken
Jul 24, 2014 01:08 PM
Mr. Feathers
Nov 25, 2013 03:09 PM
mike213735
Oct 2, 2013 12:57 AM
