05 xj8l codes p0037 p0057 p1646 p1647 O2 sensors
Old Oct 2, 2012 | 10:17 AM
lsp's Avatar
lsp
Default 05 xj8l codes p0037 p0057 p1646 p1647 O2 sensors
Hi Everyone:
I am getting the above-mentioned OBD2 codes -- all relate to the O2 sensors, I believe -- both banks, upstream and downstream.
Any thoughts as to likely cause(s)? It seems unlikely to me that all 4 would fail at one time for independent reasons, so possible explanations and/or things to check would be most appreciated.
Thanks in advance.
Old Apr 28, 2015 | 01:10 PM
sixpackd's Avatar
I'm getting the same thing.
Any recommendations on which to look at first?
Fuses, Relays? wiring?
or start out by replacing all 4 sensors?
Thanks for any input.
Old Apr 29, 2015 | 01:02 AM
JagV8's Avatar
Handbook should list fuses, relays etc else grab JTIS. May well be wiring/connector. Else change sensors but if both went bad at once it just can't be the sensors.
Old Apr 29, 2015 | 05:33 PM
sixpackd's Avatar
Checked fuse 33 and 34 in the engine compartment fuse box, both are good
R12 in the engine compartment fuse box says its not user serviceable.
I guess next step is just to start replacing o2 sensors.
Old Jul 4, 2015 | 12:37 PM
03Xtype's Avatar
Originally Posted by lsp
Hi Everyone:
Thanks in advance.
Any update on your problem? I have the same issue, is your engine burning oil?
Old Jul 5, 2015 | 05:40 PM
03Xtype's Avatar
The first thing that comes to mind is a vacuum leak. I can't imagine all the sensors going bad at once. I'm going to hook the smoke machine up tomorrow.
Old Jul 6, 2015 | 12:37 AM
03Xtype's Avatar
Jag scanner also pulled up a fuel pressure code, another thing to look in to
Old Jul 6, 2015 | 06:28 AM
lsp's Avatar
lsp
My dealership replaced all 4 sensors, then there was 'still a problem.' I believe they found a short in the wiring.
Old Jul 6, 2015 | 09:05 AM
sixpackd's Avatar
Havent troubleshooted it yet,
Not burning oil, that I know of, but I'll look into it.
however I can tell you that I have gone into limp back mode one time since all faults where there. Other than the one time, no other major issue.
I need to get the jag lifted, so that I can swap out all 4 o2 sensors.
do you know where the short was?
thx
Old Jul 6, 2015 | 02:31 PM
03Xtype's Avatar
Thank you for the update, do you have any idea what part of the loom is the trouble spot. I'll start checking my harness. In the past I had an intermittent issue with a right bank o2 sensor so this is starting to make sense.
Old Jul 6, 2015 | 04:17 PM
03Xtype's Avatar
Smoke machine showed no vacuum leaks. I didn't find any obvious issues with a quick visual inspection of the wire harness. Before testing wires I'm going to change the fuel filter and check fuel pressure.
Old Jul 6, 2015 | 10:32 PM
03Xtype's Avatar
At the moment all o2 sensors are functioning normal. Fuel pressure is between 53-55psi, AllData shows the pressure should be between 58-72.5psi. Maybe dealing with a failing pump? Tomorrow I'll test the pressure on my other Jag and go from there.
Old Jul 8, 2015 | 06:23 PM
03Xtype's Avatar
From the fuel pressure posts I've read it seems like my fuel pressure range is the norm, so in other words Alldatadiy.com can't be trusted. I reset the codes and put some miles on the car waiting for some fresh codes, so far all the monitors are set so no issues. At the moment with no clear problem I'm at a stand still, maybe bad gas set the code? Let me know if you guys come up with some better info.
Old Jul 10, 2015 | 05:48 PM
03Xtype's Avatar
Fresh codes: P0037, P1582, P0057, P1647, P1646
Old Jul 10, 2015 | 07:03 PM
03Xtype's Avatar
ordered 2 upstream O2 sensors
Old Jul 15, 2015 | 11:54 AM
03Xtype's Avatar
All O2 sensors are good, CEL comes on quicker now, time to start hunting down this wiring problem, any suggestions on approximate problem area in the loom would be much appreciated.
Old Jul 16, 2015 | 08:40 PM
03Xtype's Avatar
any one know the grounding point location for the 2 upstream O2 sensors? I just show E140 & E142 on the grounding discription.
Old Jul 19, 2015 | 09:37 PM
03Xtype's Avatar
Installed this ecm in to my other Jag, sdd failed to recode this ecm to the new car, ECM doesn't show any water contamination.
Old Jul 23, 2015 | 12:25 PM
03Xtype's Avatar
Did a good cleaning on 7 grounding points on the front end, reflashed the ecm. Back to hunting down the short or bad ecm.
Old Jul 26, 2015 | 03:23 PM
03Xtype's Avatar
Testing information for our codes P0037, P0057, P1646, P1647
<a href="http://s69.photobucket.com/user/CarBizindio/media/1_zps7jnmcajk.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/1_zps7jnmcajk.png" border="0" alt=" photo 1_zps7jnmcajk.png"/></a>
<a href="http://s69.photobucket.com/user/CarBizindio/media/2_zpsmsykxrqp.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/2_zpsmsykxrqp.png" border="0" alt=" photo 2_zpsmsykxrqp.png"/></a>
<a href="http://s69.photobucket.com/user/CarBizindio/media/3_zps8fugrrky.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/3_zps8fugrrky.png" border="0" alt=" photo 3_zps8fugrrky.png"/></a>
<a href="http://s69.photobucket.com/user/CarBizindio/media/4_zpseqaloq0g.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/4_zpseqaloq0g.png" border="0" alt=" photo 4_zpseqaloq0g.png"/></a>
<a href="http://s69.photobucket.com/user/CarBizindio/media/5_zpsvlllmge7.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/5_zpsvlllmge7.png" border="0" alt=" photo 5_zpsvlllmge7.png"/></a>
<a href="http://s69.photobucket.com/user/CarBizindio/media/6_zpsajmdx9el.png.html" target="_blank"><img src="http://i69.photobucket.com/albums/i73/CarBizindio/6_zpsajmdx9el.png" border="0" alt=" photo 6_zpsajmdx9el.png"/></a>
