05 XJR fuel pump delivery
Old Jun 11, 2019 | 08:23 PM
Stosh1017's Avatar
Default 05 XJR fuel pump delivery
Hi guys.. I have a big problem.. I can't figure out how to get my fuel pump lines routed to the other side... I have removed the drivers side... Someone else has been in here before and I believe that they have used different tubes than the original ones. So it's making it difficult for me to figure out how to connect back to the passenger side pump assembly... PLEASE HELP... THANKS
Old Jun 12, 2019 | 07:09 AM
paddyx350's Avatar
I've had the pumps in and out of my xjr a few times now
I'm not clear what you've got a problem with?
Is it physically getting the 3 black tubes that are part of the right hand pump module over to the left hand side of the tank for re connection to the left module?
Old Jun 12, 2019 | 01:40 PM
Stosh1017's Avatar
I would be able to explain better speaking with you directly.. Garry@501-520-8743....my issue is the where the fuel lines should be at the pump assembly and also connecting to the other side... from the pictures I've seen, someone has made some changes to the fuel lines..
Old Jun 12, 2019 | 04:22 PM
paddyx350's Avatar
Hi Garry,
I have a set of second hand pumps on my bench at the moment, I'm about to put them in my xjr to try and solve some problems I've got with the existing ones.
This is the left hand pump module if you're looking towards the front of the car.
From top to bottom the pipework connections are;
1) fuel transfer pipe from right hand side of the tank/pump module to the left
2) fuel transfer pipe from left hand side of the tank/pump module to the right
3) fuel feed from the right hand pump module to the engine
If you send me a pm I'll send you my number and we can talk if you like
I'm in Ireland so we might be in different time zones
Old Jun 12, 2019 | 05:01 PM
Stosh1017's Avatar
The picture is great... would you please send me a few more... one picture of the other 3 sides... with the assembly standing just like you have it...this will definitely be what I need to see..... I hope... thanks Paddy.... how do I PM you??
Old Jun 12, 2019 | 05:21 PM
paddyx350's Avatar
Here you go;
To send a pm move the cursor over my username at the top of the post and the drop down menu that appears should give you the option of sending me a message.
Old Jun 12, 2019 | 05:26 PM
Stosh1017's Avatar
The pictures are perfect and much appreciated... Thanks again for your time and help...if I have any other questions I will PM you....
Sean B
May 19, 2024 11:13 PM
Silo
Jan 21, 2019 05:03 PM
webbeing
Aug 18, 2018 10:49 PM
Thomas O'Neill
Mar 20, 2018 05:01 PM
car5car
May 18, 2016 05:16 AM
