2001 XJ8 Cabin Filter
Old May 19, 2009 | 08:52 AM
FrankF's Avatar
Default 2001 XJ8 Cabin Filter
I would like to change the cabin filter on my 2001 XJ8 VDP. Does anyone know where I can find it and how easy/difficult it is to replace? Thanks
Old May 19, 2009 | 01:25 PM
mosesbotbol's Avatar
Just changed it on my '04 and it was pretty easy. Setting the filter into its frame and then making sure all the bottom clips connect was the only halfway difficult part. Takes about 5 minutes to do it correct.
Best price I found on the filter was actually at the dealer!
Old May 20, 2009 | 07:03 AM
FrankF's Avatar
Default Re: cabin filter
Thanks, but where is it located?
Old May 20, 2009 | 07:26 PM
hlgeorge's Avatar
It should be in your owner's manual. 04 was the start of the new body and not the same as the 01.
Old May 20, 2009 | 09:11 PM
wazari's Avatar
Frank F, first off you're in the X350 section (04 XJ's and newer) so might get a better reponse in the X308 (98 to 03 XJ section). Your car is a X308 series.
The X308's have a permanent type cabin air filter which is not designed to be removed and replaced on a regular basis. The filter is under the dash and part of the heater/Ac matrix. The part alone is about $240 for the filter and probably 4 hours labor to replace.
Old May 27, 2009 | 12:37 PM
Standing at front of the car, looking at the engine, it's on the passenger side under the cowl cover. You see a 10" wide cutout in the vinyl with two latches. Those pop open and you'll see the cabin filter. Kind of press down and toward the front of the car, the cabin filter frame will pop out with the filter.
Clean the area out with a shop vac if you have one and make sure the filter is in the frame good and when you put it back, it catches on the mounting points.
The driver's side, I think it is fuses... Good luck
Old May 27, 2009 | 01:11 PM
wazari's Avatar
The original post said his car is a 2001 (X308). An '04 is a X350. Your instructions would not pertain to his car.
Sprayall
May 30, 2021 08:13 AM
picard
Oct 12, 2015 11:56 AM
tsimms7
Sep 15, 2015 12:43 PM
TexasCat
Sep 8, 2015 04:36 AM
Sprayall
Sep 3, 2015 07:49 PM
