2004 mp3 capable?
Old Mar 31, 2013 | 08:44 PM
Xeno's Avatar
Originally Posted by H20boy
I'm confused, you'd rather have an MP3 disc with a limited number of songs permitted on a 700MB disc, plus the associated longer player read times, and you'd rather install an aftermarket head player instead of putting every single MP3 song you own on a disc or thumbdrive the size of a quarter, and utilize a single electrical component that integrates perfectly with your factory deck and sound system? You do realize, you can copy MP3 from disc to drive/SD card, right?
I would. I used to use an iPod in my car. Switched to an MP3 disc player because it was easier to burn audio onto a CD than to get it onto the iPod (damn thing won't let you copy files; it insists on "syncing", which means if you copy a file onto your iPod from your work computer, it will erase everything you copied onto it from your home computer), and FAR easier to grab a CD from the overhead visor and pop it into the CD player than to find a new album on the iPod while driving.
Old Apr 1, 2013 | 08:28 PM
H20boy's Avatar
Ipod is not the same thing as an SD card plugged into a USB port of the ACM. Its as aesry as dragging from one folder to another on the computer. I dislike I-anything.
Old Apr 2, 2013 | 04:59 AM
XJ6D2005's Avatar
There is a software called "Floola" (***.floola.com). Try it instead of itunes. It doesn't erase files which are no longer on the computer, that is actual connected to the ipod.
Oh, and best part: It's free.
Old Apr 2, 2013 | 03:34 PM
Xeno's Avatar
Originally Posted by Anticitizen
Here's what I ended up doing:
https://www.jaguarforums.com/forum/x...61/#post649711
klfong:
Whoa, so, what... our cars WILL play MP3 discs? I never bothered to try. This interests me because the audio quality would be a lot higher than running through an aux cable/bluetooth from a smartphone! I've got a CD changer and another CD drive in the dash, why not load it up with MP3's? And do the steering wheel controls work with it?
I think I will burn a disc today and experiment...
EDIT: Tried it, didn't work. First I tried it with the MP3 files in folders. Then I tried it by putting all the files flat in the root directory and removed all album art files. Tried it in both the head unit and the changer. It says 'playing' and ticks away seconds but there's no sound, and if you hit the 'next track' button it just restarts with the silent 'track 1' that never ends. Ah well...
2004 XJ8. I have a CD player in the dash and a CD changer in the trunk. Neither plays MP3s.
Old May 16, 2016 | 02:25 PM
Slobodan Popovic's Avatar
after reading all this can someone assist me with this problem?
what kind of flash drive should i use...it worked before and just stop...
Old Aug 4, 2016 | 05:50 AM
9 LIVES's Avatar
Here's what I do. Plugs into my MP3 player or phone.<br/>Works perfectly.<br/>Cheap too.
kingdom worker
Nov 14, 2020 03:47 PM
kingdom worker
Oct 2, 2015 05:43 AM
MrWhite
Oct 1, 2015 01:43 AM
millertic
Sep 30, 2015 08:11 PM
caldoofy
Sep 28, 2015 08:43 PM
