2004 VDP: that Dreaded Suspension Fault - Guidance Please!
Plus Vehicle Too Low. Hoping some of you can point me in the right direction, I am a DIYer so I hope to start in the right track to solve this problem:
CLUES:
APPROACH?:
Much thanks and I know this is common, but I need experts here to consider the clues and help me find the best repair approach (no kitchen sinks please ;-). Christmas is upon us and this comes at a very bad time perhaps.
CLUES:
- 101K miles
- This summer, new compressor after Suspension Fault (97K), no faults since
- Every so often you hear a quick burst of air with car off while in the garage, very infrequent
- Today coldest day yet, 22 Fahrenheit
- 20 minutes into commute, yellow light Suspension Fault
- 5 minutes later, red light Vehicle Too Low message
- Front end of car very low
APPROACH?:
- This is where I need guidance. I guess I need something beyond an ODBII scanner to read the suspension codes?
- Does the compressor seem the culprit? Both sides of the front end equally low. See pic.
- Is there a fuse or relay to check to start off?
If you only just replaced the air compressor, I would not be suspecting that, unless it is a Joe Noname product. The system recognises the front of the vehicle is too low, so the height transmitters seem to be working OK. The front units are controlled together so it looks like you may have an air leak in one or both of them. It is normal to hear an air release on return from a reasonably long run. This is the system blowing air back through the compressor and the drier to blow out the accumulated moisture back to atmosphere, so totally normal action.
It really is essential you read the fault codes before buying expensive spare parts that may not address the issue. With the low temperatures you mention, I would not be surprised if the seal at the top of the air spring is leaking. However, you could have suffered a catastrophic failure of one or even both of the front air spring diaphragms. Can you hear any air escaping at the front ?
Don B (12-20-2019)
So after the work day, I went to the parking garage and I did the reset process for the air suspension, that is turn the car on and then off, then ignition on and then ignition off, started the car and let it sit for couple minutes, upon that time, compressor came on--I could hear it--and started lifting the front end of the car which was a big relief. The error code "vehicle too low" went away and everything was fine. I drove home without any issues. When I got home and in the garage, turned the car off, open the hood, and I could faintly hear some air escaping from the top of the passenger shock in the front. This only lasted for about 30 seconds and totally stopped. It seemed to come from the connector area at very top of shock and not from the air supply hose. Once air noise gone, I measured the height from fender to the floor and on that side, the car was 3/8 of an inch lower than the driver's side. Driver side 27 1/8, passenger side 26 3/4 height measured in inches inside of wheel well to floor.
What do you all think?
And thank you for the replies.
RMT stood by their product and sent a replacement shock right away.
Finally got it in today, along with new upper control arms both sides, no problems there.
But, here pictured is the reward, Yellow light along with CATS SYSTEM FAULT
...Almost starting to think I should have just done a conversion to conventional. Although the system pressurized well and both front wheels are at equal and adequate height. I never disconnected the battery, I do not like doing that.
The system seems to be working well except for the error message, and yes I did plug the shock back up.
I was hell getting one of the control arms nuts off, had to torch off the grease and rubber to grab the bolt so it would not turn along with the nut. The 5 MM hex key in the bolt being spun round.
Thanks, compressor seems to be running fine. I think the check valve in the shock is worn or not good, or whatever it is that the two tiny wire connect to.
I did a test, took the RMT shock that was leaky and hooked it up instead, no errors at all. Gonna give it a drive into work tomorrow and that is it, then changing approach. When I am done, we will all learn some lessons at my expense.
Notice no yellow error light.
If I disconnect the battery for 15 minutes, will it clear the CATS error codes?
Only thing is that as soon as I connect this strut, CATS fault comes right up with yellow light, the other strut, no error. Maybe it has a stuck solenoid valve.
