2004 XJ8 car running on lift Question
Have a 2004 XJ8 with air suspension and going to being changing transmission pan because of leak,i know there are times when the car has to be running on the lift when filling and checking fluid,just wondering if the car will go way up or down with the air sensors,i believe there is no shut off for the system
Albert
Albert
The Air Suspension Control Module (ASM) recognizes when the vehicle is raising but does not lower in response to commands to do so and responds by entering "Jacking Mode," which disables any further attempts to raise the vehicle. To exit Jacking Mode you only need to drive the vehicle at least 2 mph.
Cheers,
Don
kevo
Sep 8, 2015 09:45 AM
Lagonia
Dec 29, 2013 04:46 PM
Windycityx
Nov 29, 2012 12:47 PM
maikal_0011
Jul 18, 2010 07:42 AM
FriendlyXJ
Dec 29, 2008 08:16 PM
