2004 XJ8 CATS System Fault
Old May 7, 2014 | 01:49 PM
bezzy's Avatar
Don, With engine running I press down on suspension and after five presses the suspension locks solid. Is this normal.
cheers
steve
Old May 7, 2014 | 08:01 PM
Don B's Avatar
cheers
steve
Hi Steve,
I just tried this on our '04 XJR and it behaves exactly the same way. On the fifth press it hardens up. I can only assume that the system is stiffening up the suspension in response to the excess motion sensed by the vertical accelerometer.
BTW, I am very careful when pressing on an aluminum-bodied car.....
Cheers,
Don
Old May 8, 2014 | 06:21 AM
bezzy's Avatar
Don, Thanks for all your help ,looks like the local Jag garage will be getting more of my hard earned cash.
cheers
steve
Old May 8, 2014 | 09:11 AM
Don B's Avatar
cheers
steve
Very sorry, Steve. Please keep us informed.
Cheers,
Don
Old Sep 17, 2015 | 01:22 PM
bezzy's Avatar
Well new battery fitted and it still rides like a roller skate
Old Sep 19, 2019 | 02:30 AM
EsRay's Avatar
Originally Posted by abonano
have the dealer clear the codes and see if they come back. I will tell you from experience - only Jaguar level software can clear the codes from the ADCM.
Abonano, I realise this is a very old post......However I have a persistent C2304 code which I cannot clear with my iCarsoft LR V1.0 code reader, despite performing all the pinpoint tests successfully (i.e. all ohms and volts at the 4 dampers are now correct....I had a poor connection at ASM CR89)?
Shouldn't the code clear itself if the root cause is eradicated ? Or do you think that what you say above the case, please?
Old Sep 19, 2019 | 09:03 AM
Don B's Avatar
Hi Ray,
Until abonano replies I'll chime in. First of all, congratulations on figuring out the poor connection at CR89. Good work!
Secondly, for whatever reason, some of the ASM DTCs do not want to clear on their own even after a fault has been corrected. Jaguar/Land Rover SDD can clear the codes, but I also have an Autel MaxiSys Elite that can read and clear virtually all Jaguar codes, including those for the air suspension. I suspect that other professional systems by Launch, Autologic and AutoEnginuity can also clear these codes, and possibly some of the higher-end scan tools from SnapOn, MAC, Matco, Cornwell and OTC/Bosch. If you have a good independent shop in your area that works on European cars, they probably have one of these systems and may be willing to scan and clear your codes for a modest diagnostic fee.
Cheers,
Don
Old Sep 19, 2019 | 03:18 PM
  #28
abonano's Avatar
Originally Posted by Don B
Hi Ray,
Secondly, for whatever reason, some of the ASM DTCs do not want to clear on their own even after a fault has been corrected. Jaguar/Land Rover SDD can clear the codes, but I also have an Autel MaxiSys Elite that can read and clear virtually all Jaguar codes, including those for the air suspension. I suspect that other professional systems by Launch, Autologic and AutoEnginuity can also clear these codes, and possibly some of the higher-end scan tools from SnapOn, MAC, Matco, Cornwell, OTC/Bosch. If you have a good independent shop in your area that works on European cars, they probably have one of these systems and may be willing to scan and clear your codes for a modest diagnostic fee.
Cheers,
Don
EsRay, Don is absolutely correct. Aim for SDD or any of the other platforms mentioned. If the code persists there may be further issues.
Good luck
mhminnich
Jun 10, 2017 08:32 AM
grantorino62
Apr 4, 2016 09:22 PM
Ericbilt25
Mar 4, 2014 02:08 AM
User 070620
Sep 20, 2013 09:28 AM
pomosv
Jul 18, 2011 02:52 PM
