2004 XJ8 hard shifting after warmed up
Old Mar 24, 2025 | 01:03 PM
TommyBoah's Avatar
Default 2004 XJ8 hard shifting after warmed up
Hey everyone!
One thing I've been noticing with my XJ8 is that the car has a tendency to shift from 2nd to 3rd gear pretty hard after the engine has warmed up. Oddly enough, it didn't occur when the engine/transmission is cold, all gears shifted smoothly and snappy. I've replaced the mechatronic seal, transmission fluid pan, and filled the transmission with the proper level of fluid, indicated by a steady dripping at 40 degrees Celcius. What could likely be the cause of this issue? Thanks in advance!
Old Mar 24, 2025 | 04:25 PM
motorcarman's Avatar
Info for you.
Been a problem for a few decades.
Old Mar 24, 2025 | 08:01 PM
TommyBoah's Avatar
Info for you.
Thanks for the info! Can a dealer or an independent Jaguar specialist perform the software update?
Old Mar 26, 2025 | 02:10 AM
Petz's Avatar
Also might be related in some cases.
Rear wheel speed sensors and reluctor rings.
Old Mar 26, 2025 | 02:24 AM
Petz's Avatar
Generally after an oilchange you do not need to reset adaptations over Sdd . With new seals and fresh oil inside tranny, pressure loss improves( milli bar) to some degree Tcm module is capable of regulating necesssry pressure adjustments all by itself but it takes some time and miles. Drive cycle is the better solution If you do a rebuild you would need to do a reset
withersjw
34
Mar 26, 2025 02:54 AM
goldgun
22
Aug 28, 2022 10:22 AM
stremsjg
Aug 27, 2016 06:00 PM
7Watts
Feb 11, 2015 12:38 PM
BobC
May 10, 2011 11:56 AM
