2004 XJ8 Power steering failure + overheating.
Old Jul 18, 2018 | 03:02 PM
Azartist's Avatar
Default 2004 XJ8 Power steering failure + overheating.
Hello,
I am so hoping that I can get some insight into the following!
I was driving down the freeway here in Phoenix last night in my 2004 XJ8 with my daughter, when all of a sudden I hear a high pitched squeal for about 10 seconds, followed by the battery light coming on, loss of power steering, and temperature gauge rapidly climbing.
i slowed down and pulled over as quickly as I could and turned off the engine. I popped the hood while The fan continued for a while, and once cooled, I noticed that the PS res was bone dry (I just changed my oil the previous weekend and checked fluids... all good). I also lost some coolant. I ended up towing it.
Any idea what I am looking at? I am not a mechanic at all... any advice would be greatly appreciated!!
Old Jul 18, 2018 | 05:31 PM
Welcome to the forum Azartist,
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about your model.
Old Jul 19, 2018 | 02:37 AM
Originally Posted by Azartist
.....a high pitched squeal for about 10 seconds, followed by the battery light coming on, loss of power steering, and temperature gauge rapidly climbing. .....
I expected there would have been some replies before now. My thoughts to get the discussion going.
1. the squeal suggests either the drive belt or an accessory issue.
2. the battery light coming on suggests the alternator was no longer rotating.
3. temperature rising suggests water pump no longer rotating.
3. an empty PS reservoir/loss of power steering suggests a broken pipe or steering rack seal.
You did exactly the right thing to stop and have the vehicle towed. Overheating a Jaguar V8 is an engine killer.
The simplest explanation is the Drive Belt (often called the 'serpentine' belt) has broken:
As can be seen from the diagram, it drives the Water Pump, Power Steering Pump, AC Compressor and Alternator (generator). Once the belt stops turning, so do all these accessories.
A second possibility is the Tensioner (item 2) has seized. This is a spring loaded pulley which keeps the drive belt under tension. It is a known failure on the V8 engine.
The loss of PS fluid raises a third possibility - power steering pump failed.
Your prompt action has almost certainly avoided catastrophic engine damage but, if you are not able to DIY repairs, the cost could still be an unpleasant surprise if it turns out to be the power steering compressor.
Old Jul 19, 2018 | 08:10 PM
Azartist's Avatar
Thank you for the reply, Graham.
I heard back from the local Jaguar shop I had it towed to. Got a call later in the day with this diagnosis:
Siezed AC compressor. AC seized up and the serpentine belt was consequently shot.
$1800 to fix. Ouch. What a rude awakening to the world of the Jaguar!
Old Jul 20, 2018 | 04:13 AM
Fraser Mitchell's Avatar
Yes, they can be expensive sometimes. Still doesn't explain the loss of PS fluid, thiugh.
Old Jul 20, 2018 | 10:13 AM
Azartist's Avatar
I was thinking the same thing. I explained the loss of PS fluid to shop. I'll be picking up car today, I'll post what the fix was and $$.
Old Jul 20, 2018 | 05:22 PM
meirion1's Avatar
"I heard back from the local Jaguar shop I had it towed to. Got a call later in the day with this diagnosis:
$1800 to fix. Ouch. What a rude awakening to the world of the Jaguar!"
That's bad luck-a very rare fault AFIK.
Old Jul 21, 2018 | 06:14 PM
Azartist's Avatar
Bad luck indeed! Car is fixed, blowing ice cold air, and running great... just like it was before the AC failure. Keeping my fingers crossed that my love of driving this car doesn't outweigh my bank account!
Old Jul 22, 2018 | 02:21 PM
Any reason for not having any PS fluid in the reservoir ?
BTW, glad to hear you're "up and running" as the IT industry guys would say !
Old Jul 22, 2018 | 04:54 PM
Azartist's Avatar
No reason given, other than the shop owner indicating that there was fluid in it... just low. All fluids all topped off.
slburns538
51
Aug 16, 2019 10:49 PM
AZ RICH
Jun 12, 2018 01:35 PM
sunchip
Jan 28, 2015 08:21 AM
MarcB
Jan 16, 2012 10:29 AM
xylorex
31
Oct 10, 2011 12:17 PM
