2004 XJ8 Steering Column Tilt
Old Apr 4, 2015 | 09:36 AM
chris2806126's Avatar
Default 2004 XJ8 Steering Column Tilt
I am having a problem with the tilt on the steering column. it seems to move up or down but only travels about a 1/4 of an inch. the in and out seems to travel the normal distance. i have notice that it uses the same motor to activate both. Is this a memory problem or limit switch problem? having problems to see the speedo as I am tall and the wheel does not tilt up enough. seem to start acting this way after flashing central control module.
Old Apr 15, 2015 | 01:46 PM
After taking the bottom covers off below the steering column, I found the resistors for the tilt adjust. it's actually one unit for both tilt and extend. I took it loose and manually slid the slider and was able to move (tilt) the column up and down. I tried spray cleaning it but it still didn't work when placed back to normal condition.
So to solve a simple problem of tilt adjust, I adjusted it the the position that was best for me and disconnected the movement switch so no one can adjust it. I do miss the move away feature when entering or exiting the vehicle.
I am going to research the part to see if there is a replacement.
File Type: bmp
File Type: bmp
tomsjag
Jun 10, 2023 10:02 AM
kevinl
Oct 31, 2019 06:15 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Jackieo123
Sep 14, 2015 09:03 PM
mhenz
Sep 14, 2015 07:47 PM
