2004 XJR upper wishbones front
Old Sep 11, 2012 | 06:29 PM
luv2fly's Avatar
Question 2004 XJR upper wishbones front
I've been searching the forums for an answer and maybe I've overlooked it. I need to replace the upper control arms on my 04 XJR. I know I need to remove, or at least drop the air shock to get the a-arm bolts out. If I unplug the air line and the electrical connection at the top of the shock, will that set a code that requires the $200 Jaguar reset and calibrate routine? Doesn't look like there's enough room to lower the shocks with wires and air lines attached. Just wondering if this a job I can do, or might I just as well take it in and let the Jag store do it? Already have the a-arms thanks to a post referencing justjagsuk.com.
Thanks,
Dale
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Sep 25, 2015 11:09 AM
philwarner
Sep 6, 2015 11:10 PM
Tar
Sep 6, 2015 11:24 AM
Numwen
Sep 6, 2015 12:30 AM
